found another problem... - Page 2 - JeepForum.com
post #16 of 21 Old 05-04-2001, 01:01 PM
osburn
osburn's Avatar
If you do like I did and just order axles to your specs, Dana 44s are not that much cheaper than 60s. Well, maybe about 1K per axle cheaper. That's why I ordered 60s.
I have a buddy running a Currie 44. It will be for sale soon because it is a piece of ****. Currie takes a lot of shortcuts on the 44s.
Unless you have a good chunk of savings you can afford to dip into, then rayray's advice about building them yourself might be a better route. Jeffy actually got a Dana 44 under the rear of his YJ for a remarkeably low price. I'm sure he'll pipe up soon.
Matt Osburn
Score 1032
osburn is offline
post #17 of 21 Old 05-04-2001, 02:47 PM Thread Starter
Tonka
2015 JK Wrangler
son of a...
aaahhhhhh!!!!
sorry, needed to vent. Well, now that the axle is back together, the starter decided to take a s**t. At least that has a lifetime warranty. It's always something, I'm under it more than I'm in it.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #18 of 21 Old 05-04-2001, 03:37 PM
rayray
rayray's Avatar
Damn dude! Who did you piss off in a past life???
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #19 of 21 Old 05-04-2001, 11:20 PM Thread Starter
Tonka
2015 JK Wrangler
I just happened to get one that wasn't maintained or was abused. I pulled up a carfax report after finding some body damage that wasn't repaired properly. It turns out that it was a company vehicle at one point in time, and has no accident history.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #20 of 21 Old 05-04-2001, 11:25 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
What's the web address for carfax?
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #21 of 21 Old 05-04-2001, 11:55 PM Thread Starter
Tonka
2015 JK Wrangler
It does cost you a little bit, but IMO its worth it.www.carfax.com
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
think I found my problem.. jdub2k5 TJ Wrangler Technical Forum 9 02-06-2010 08:22 PM
Found the problem with my AC, how do I go around fixing it? usurp TJ Wrangler Technical Forum 5 03-09-2008 02:05 PM
Got in some water, found a problem Jakemd98 TJ Wrangler Technical Forum 7 06-16-2007 08:29 PM
found the problem mean90yj YJ Wrangler Technical Forum 3 03-18-2007 05:27 PM
Found problem with 4WD, now how to fix.... Jesta YJ Wrangler Technical Forum 15 02-01-2005 08:09 AM
