found another problem... - JeepForum.com
post #1 of 21 Old 05-02-2001, 07:34 PM Thread Starter
Tonka
2015 JK Wrangler
yet anouther problem rears its ugly head.
I took apart the rear diff again because the axle shaft and other related parts should be here tomorrow. I cleand the oil off of everything and found a crack in my carrier.
between loosing my job, the spiders going,and the axle breaking(taking the passenger side rear brakes with it) I am flat f***in broke. I don't know how to set backlash, etc.
If anyone can explain how to properly replace the carrier and set the backlash, etc. Please post. I have the dana(junk)35c rear. I also need prices on the carrier 4.11 gears and abs.
Thanks in advance,
Eric
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #2 of 21 Old 05-02-2001, 07:47 PM
Cody_91YJ
Man, you have all the luck
Well, really I'd suggest not doing it yourself if you've never done it before. You've gotta get it just right or your gonna have a lot more problems.
For gears you'll send around 130-150 bucks, the install kits run about 50 bucks for the Master kits.
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #3 of 21 Old 05-02-2001, 10:25 PM Thread Starter
Tonka
2015 JK Wrangler
I don't have the money to take it in. The carrier cracked on both sides, right at the holes for the cross shaft. Does anyone know of a good source for a carrier? What other parts will I need?
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 21 Old 05-02-2001, 10:57 PM
osburn
osburn's Avatar
Dude, when I saw "found another problem" and your name next to it I just cringed. Follow that info I gave you before when you were trying to locate the shaft. I'm sure you will get help there.
Setting gears is out of my league.
Matt Osburn
Score 1032
osburn is offline
post #5 of 21 Old 05-03-2001, 06:54 AM
jeeptuff
Man Tonka you are sure gettin a run of bad luck..Sorry to hear it. For rear end anything I would check www.randysringandpinion.com I got my carrier and gears though them and they were all the help. As for backlash it is critical to be precise, you have to have a dial indicator to set it up the right way. If you've never done it find a buddy that has, help watch and learn.. Best of luck to you, I feel for ya!!!
Eric
Once again Jeepless in Seattle
jeeptuff is offline
post #6 of 21 Old 05-03-2001, 01:36 PM Thread Starter
Tonka
2015 JK Wrangler
For some unknown reason, The Jeep Gods don't like me. I'm at the point where I'm pretty much stuck. I'm afraid that if I fix the rear that I have,something else is going to break. On the other hand, If I buy a used rear, I'll probably have to re gear it before I can use it.Either way I go, I'll have to borrow money.
I was supposed to start a new job next week. Of course there is no one near me to get a ride with.
To top it off, I've already spent $550(borrowed money)on this rear.
I hate to say this, but I wonder what I will break next?
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #7 of 21 Old 05-03-2001, 06:14 PM
jeffy
jeffy's Avatar
You sould be able to replace the carrier yourself! It's easy. Nothing to set. Get a new carrier and then have some new bearings pressed onto it. $10 each for the bearings. Order some new ring bolts while your at it. The shims for the carrier are on the outside. So as long as the carrier and the bearings are the same as those taken off the old carrier then it should go back in as it was before.
Oh yeah, I did my mown gears in a car port with jackstands.
*** www.4BangerJP.com ***
jeffy is offline
post #8 of 21 Old 05-03-2001, 06:58 PM Thread Starter
Tonka
2015 JK Wrangler
How do you pull the carrier?
I have the bearing caps off, But I cant get it to loosen up. I dont want to risk the hammer/pry bar approach unless thats ok.
Thanks in advance.
jeffy, thanks alot the advice will save me some $$$
osburn, how much do the dana 60's you have run?
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #9 of 21 Old 05-03-2001, 07:14 PM
rayray
rayray's Avatar
Be sure to pull the axle shafts out.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #10 of 21 Old 05-03-2001, 07:27 PM Thread Starter
Tonka
2015 JK Wrangler
the axles are out, the locker is out, and the bearing caps are off.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #11 of 21 Old 05-03-2001, 07:31 PM
rayray
rayray's Avatar
use a pry bar and pry from the bottom. It should come out fairly easily. Work it side to side if need be. Try and pry ( rhyme time) from the center of the carrier mostly. If it get's to cock eye'd, it'll be harder to get out.
rayray
rayray is offline
post #12 of 21 Old 05-03-2001, 07:35 PM Thread Starter
Tonka
2015 JK Wrangler
Thanks, I'm heading outside to do it now
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #13 of 21 Old 05-04-2001, 01:04 AM
osburn
osburn's Avatar
You really don't want to know. Are you sitting down? I paid about $10K for two axles. I know, it's obscene.
Matt Osburn
Score 1032
osburn is offline
post #14 of 21 Old 05-04-2001, 02:27 AM Thread Starter
Tonka
2015 JK Wrangler
OUCH! I think I'll be going with the dana 44's. Any experience with Currie's?
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #15 of 21 Old 05-04-2001, 12:17 PM
rayray
rayray's Avatar
Tonka,
10k for the two axles is about the going rate. Sunray's 9"/D60 hybrids are about the same price. Having D44's build probably will burn a good size hole in you wallet as well. I would highly suggest building them your self or just investing in spare D35 parts. Remember, you don't have to build a jeep over night. There is no race to the finish. And, it's IMO and probably the opinion of other's that, if you can learn to drive your rig in various stages, by the time you get your rig done (as if that's possible), you will have aquired priceless driving skills. Just ask a few how long it's taken them to get to where there at. I'm goin on 5 years myself.
rayray
rayray is offline
think I found my problem.. jdub2k5 TJ Wrangler Technical Forum 9 02-06-2010 08:22 PM
Found the problem with my AC, how do I go around fixing it? usurp TJ Wrangler Technical Forum 5 03-09-2008 02:05 PM
Got in some water, found a problem Jakemd98 TJ Wrangler Technical Forum 7 06-16-2007 08:29 PM
found the problem mean90yj YJ Wrangler Technical Forum 3 03-18-2007 05:27 PM
Found problem with 4WD, now how to fix.... Jesta YJ Wrangler Technical Forum 15 02-01-2005 08:09 AM
