Fouled Plugs - JeepForum.com
post #1 of 8 Old 05-20-2012, 05:56 PM Thread Starter
CJ51973
CJ51973's Avatar
Fouled Plugs
I am fouling plugs pretty quickly. What do these pictures mean to anybody?
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #2 of 8 Old 05-20-2012, 06:26 PM
gunshw301
I am no engine expert nor can help with a cause but it looks lean to me. Plug is getting to hot.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 8 Old 05-21-2012, 08:48 AM Thread Starter
CJ51973
CJ51973's Avatar
I am running a TFI with 12 volts to the coil. The ignition module is still stock voltage (use old coil (+) to trigger a relay for 12 volt coil voltage). Is this too much for the stock plugs? I bought some $7 each plugs which are warrantied, Autolite Iridium or something like that. Fouled Bosch Platinums and Champion Copper.
CJ51973 is offline
post #4 of 8 Old 05-21-2012, 08:53 AM
USMCBuckWild
Don't laugh, but best luck I have ever had with plugs were the $.99 Champions or NGKs. I ran them with points as well as an MSD Digital 6 ign and they never failed me.
Check the temperature range the store gave you and ensure they didn't give you 'hotter' plugs.
USMCBuckWild is offline
post #5 of 8 Old 05-21-2012, 09:26 AM Thread Starter
CJ51973
CJ51973's Avatar
This is the second set this has happened to. Temperature wise you are thinking the plugs are runnig too hot so they are burning up? Or I need cooler plugs so they won't make as much heat?
CJ51973 is offline
post #6 of 8 Old 05-21-2012, 01:00 PM
USMCBuckWild
It looks to me (and I am no expert) that you might want to try cooler plugs. Just 1 step down I think. I know Toyotas and Subarus tend to like 1 step hotter...
Just my $.02
post #7 of 8 Old 06-03-2012, 04:34 PM Thread Starter
CJ51973
CJ51973's Avatar
The wires on the distributor pick up were cooked and one had welded itself to the base of the distributor. I think thi will cure this weird fouling issue.
CJ51973 is offline
post #8 of 8 Old 06-03-2012, 05:53 PM
4.7stroker
That looks like ash on the insulators, running the correct heat range keeps the plugs clean but burning oil leaves behind ash deposits like you are seeing. Are you using oil? What is your compression? Is your PCV system functioning correctly?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 08:37 PM
Fuel soaked fouled plugs no start kmn81 YJ Wrangler Technical Forum 2 03-12-2010 06:58 AM
I dont have enough spark , all plugs fouled up. grimjeeperyj14 YJ Wrangler Technical Forum 8 01-20-2010 06:45 AM
P301 & Fouled Plug + Pinging/Knocking Noise? D_Boone TJ Wrangler Technical Forum 3 10-31-2009 03:34 PM
Splitfire Plugs vs. Standard Plugs Alphadux TJ Wrangler Technical Forum 8 11-19-2003 06:35 PM
