Ford hp D44 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ford hp D44
ROCKRIDGE 4WD Newsletter about to hit your Inbox! Just in FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 11-22-2013, 10:35 AM   #1
Hotrodyj
Ford hp D44
Anyone on here running a HP ford d44 front with coils or coil overs? I'm looking at a hp d44 and 9 swap in my yj and my donor is a 79 f150. Just curious if anyone here has that setup.
Hotrodyj is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 11:00 AM   #2
fratis
fratis's Avatar
If you are looking to use a 79 and retain the ford suspension it can be done but so far I haven't seen one that would work any better then a leaf spring style setup. A 3 link would work better and not much more work.
fratis is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 11:10 AM   #3
Hotrodyj
I'm already running coils on the d30 and 35 so I'll probably keep the coil setup or go to coil overs
Unread 11-22-2013, 11:12 AM   #4
Hotrodyj
I'm just trying to decide between keeping the ford radius arm, building a truss setup to get around the cast wedges, or retubing the d44
Unread 11-22-2013, 11:18 AM   #5
Thean
I gutted my 78/79 housing and sent it to Currie.
They retube them pretty cheap.
then ran a 3 link.
I have seen a few running the Ford Radius arm type setup, most cut the arms and then built a boxed sheet metal arm that was slightly longer and had more angle to it so the brackets didn't have to hang way down below the frame rail.
Thean@DirtDrivenDesign.com
Thean is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 12:20 PM   #6
Hotrodyj
Thank you Thean. I'll check out currie
Unread 11-22-2013, 09:50 PM   #7
fratis
fratis's Avatar
If you plan to throw all the internals away and have the housing retubed then just buy a prebuilt axle assembly.
-insert meaningless out-of-place political diatribe-
Unread 11-22-2013, 09:57 PM   #8
GrantYJ
You might also search this in the XJ section. This is a pretty common setup on their rigs.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 09:31 AM   #9
Hotrodyj
If I end up deciding to retube I'll probably do it myself. No sense paying someone else to do what I can do myself. Yeah I've been looking at a lot of the xj stuff too. Thanks for the input guys. Thean do you have pics of your setup?
Unread 11-23-2013, 08:52 PM   #10
Thean
I just reused everything. Minus the stock tubes and cast sections.
Didn't change any width so shafts were a drop in and OEM replacements work.
If you have the time to press out the tubes and press in some new ones, that's the way I would go.
