ford e fan mod ? - JeepForum.com
post #1 of 9 Old 02-24-2009, 10:31 PM Thread Starter
bustednuckles
ford e fan mod ?
is the fan reversable? i don't have much clearance
bustednuckles is offline
post #2 of 9 Old 02-24-2009, 10:50 PM
jbolty
jbolty's Avatar
no. you can get it in there. Upside down. Replace the waterpump studs with bolts. Take the motor off the fan shroud and cut down the nubs it sits on to gain 1/4 inch.
jbolty is offline
post #3 of 9 Old 02-24-2009, 10:54 PM
Leans93
She's my density...
Leans93's Avatar
Another option is to go to the junkyard and grab a waterpump and pulley off of an XJ. Gives TONS of extra clearance.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #4 of 9 Old 02-25-2009, 07:44 AM
themonkeyman
1987 YJ Wrangler
Wht year XJ did you pull that from? I thought the XJ pumps had a different rotation/pump flow? I ask because I have both a taurus fan waiting to go in as well as an XJ parts car with a fresh water pump on it.....
themonkeyman is offline
post #5 of 9 Old 02-25-2009, 09:38 AM Thread Starter
bustednuckles
i pulled a 4.0 from a xj with a aw4 behind it. looks like i'll go with a aftermarket fan
post #6 of 9 Old 02-25-2009, 12:17 PM
Leans93
She's my density...
Leans93's Avatar
It came off of a 93' XJ. Same rotation and since the pulley is flat you get lots of extra room.
M.F. Leans
Leans93 is offline
post #7 of 9 Old 02-25-2009, 03:22 PM
tippmann243
does the 4.0L xj pump have a heater hose running to it on the pass side like the 4.2L do?
if im not mistaken for the heater one line goes to the t-stat housing, and i want to say one goes to the pump just like on my 4.2. if that is the case that would make e-fan instilation a LOT easier on my old carbed 6 cylinder
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #8 of 9 Old 02-25-2009, 03:40 PM
Leans93
She's my density...
Leans93's Avatar
I'm not as familiar with the 4.2L but on my 93' 4.0L there is a metal hose that screws into the water pump on the XJ same as my 93' YJ pump was. It then connects to a rubber hose that goes to the heater. The XJ pump and YJ pump I had to compare were both from 93' 4.0L's and they are basically identical except for where the pulley bolts to the pump.
M.F. Leans
Leans93 is offline
post #9 of 9 Old 02-25-2009, 03:43 PM
tippmann243
i guess i can go to the parts store and compare the 4.2 pump and the 4.0 pump.
i looked at the generic pictures and they both appear to be the same accept for the hub depth of the yj is a lot deeper.
maybe ill go to the junkyard and just pull on off since a water pump/pulley is only 5 bucks.
blazer video,
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford SVO disk brake kit on Ford 8.8 texashoghunter TJ Wrangler Technical Forum 0 07-10-2008 07:12 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
Ford 8.8 ???? mud chicken TJ Wrangler Technical Forum 12 01-31-2006 06:29 PM
Ford T18 and Ford Dana 20 JOKER4INK YJ Wrangler Technical Forum 0 11-23-2005 05:00 PM
