Ford 9" onto YJ - JeepForum.com
post #1 of 6 Old 05-05-2002, 12:03 PM Thread Starter
jeep_fun
Ford 9" onto YJ
I need to know what everyone had to do to mount their ford 9" rearends on to a YJ. This includes brakes, driveline and angle and so on. I'm dropping in a 350 small block/TH400 auto./NP205 T-Case. All help is greatly appreciated.
Adam "Drasko" Draskovich
yellow '91 YJ
2.5L, 4" lift, 33x12.50 TSL Radials
4.56 gears(both ends)
and a 350/TH400/Dana 300/Dana 44/Dana 60 coming soon
jeep_fun is offline
post #2 of 6 Old 05-05-2002, 09:29 PM
RodeoRob
RodeoRob's Avatar
Well, unless you're swapping your front axle too, you're not gonna find a 9" short enough to match your stock front. Most common 9"s are probably gonna be in the ballpark of 63-65" wide.
Also, the 9" uses a 5 on 5.5 bolt pattern, so that isn't gonna match your stock front.
Other than that, you'll have your basic stuff like moving perches/shock mounts, driveline angle will depend on the rest of your setup, brake plumbing, and so on.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 6 Old 05-05-2002, 09:51 PM Thread Starter
jeep_fun
I dont't know if you know but the width of the YJ is 60 in. and the widths of ford 9" rearend are right around 60-65...especialy the one I MEASURED TODAY. I can get away with putting extensions of the front end until i switch that dana 30 out if i need extra width. Also, if you don't think it works, go ask the rest of the YJ world what THEY use when they run V8's. Most of the time if its not a Dana, its a 9". Thanx anyway though.
yellow '91 YJ
jeep_fun is offline
post #4 of 6 Old 05-08-2002, 11:31 PM Thread Starter
jeep_fun
i know more ppl have something to say
yellow '91 YJ
jeep_fun is offline
post #5 of 6 Old 05-09-2002, 02:05 PM
rollinashortysahara
liar
there is a linclon 9" with disk brakes that was 59.5 inches wide
perfect !!! even has the same bolt pattern
rollinashortysahara is offline
post #6 of 6 Old 05-09-2002, 02:22 PM
rollinashortysahara
liar
there is a linclon 9" with disk brakes that was 59.5 inches wide versallies ( not sure how to spell it) but they are on ebay alot
ford 9" kasbiker38 YJ Wrangler Technical Forum 11 03-29-2009 09:58 PM
Ford 8.8" beachboy1200 TJ Wrangler Technical Forum 6 03-02-2009 12:30 PM
ford 9" Mayfair_Jeeper TJ Wrangler Technical Forum 17 11-17-2008 04:50 PM
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
