Ford 9 inch vs dana 44 - JeepForum.com
 5Likes
post #1 of 64 Old 03-31-2008, 09:24 PM Thread Starter
stokesj19
Which would you preffer for a back axle. I was told that a 9 inch was the equivilant to a d60.
stokesj19 is offline
post #2 of 64 Old 03-31-2008, 09:41 PM
sam.b.
prolly the ford 9 cause it would be easy to get a matching front 44 (or build a 609 up front) and the removeable 3rd member would be nice
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #3 of 64 Old 03-31-2008, 09:59 PM
Swampwalker3
1987 YJ Wrangler
It's somewhat close but I know more people who's destroyed a 9".. 3 times in one day.. than I do with 60s.
Also, 9"ers like to leak from axle seals. New seals leak.. Putting RTV on the flanges, still leaks.. Putting new seals and RTVing the flanges, still leak.. New seals, RTV, and flange seals and it usually still leaks. Usually the leaks occur within the same day to a few months depending on your method of a fix..
Now, I know of a couple who haven't had any problems, but you still have to deal with the press on bearings whenever the time comes, kinda fun when you don't have a press..
Personally, I'd go with a 60. They're the same price anyway. May be a bit bigger, but deffinately easier to deal with.
Zane Neher
88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s.
Swampwalker3 is offline
post #4 of 64 Old 03-31-2008, 10:10 PM
flame0086
This is like compairing a run down apartment to a 500k house. The people who live in run down apartments are the ones who can't aforad the house.
A real question would be 9in vs D60, or D44 vs 8.8 (which has already been extensively discussed).
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #5 of 64 Old 03-31-2008, 10:11 PM
YJ_Aaron
9" is cheaper to upgrade to bullet proof in my opinion. However the lower pinion is kinda hard on jeeps with stock wheelbase.
Dana 60 is overkill for the great majority of people.
91 YJ rebuild! Rush to get it driving/wheeling.
YJ_Aaron is offline
post #6 of 64 Old 03-31-2008, 10:12 PM
jeeepguy
jeeepguy's Avatar
A big consideration in a 9" vs D60 debate is pinion location.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #7 of 64 Old 03-31-2008, 10:26 PM
Swampwalker3
1987 YJ Wrangler
Just realized he was comparing to a 44..
I'd get a 9".
Zane Neher
post #8 of 64 Old 03-31-2008, 10:50 PM
BWR
Well, I just put this on another thread about a day ago: close to 500K on my dana ft and ford 9' on an f-150. I dread saying it-- but it went for at LEAST 200,000 miles before its first fluid change. Has seen a LOT of off road and Highway miles...not too many in city and they've held up well, but figuring the 9" in the back "runs" all the time and the front one only off road--> I think I'd say a 9" hands down.
The only trail that sucks is the one you haven't been on yet.
If it aint related to God, guns, women, wheelin, or music then it aint worth much talking about it is it?
BWR is offline
post #9 of 64 Old 04-01-2008, 08:13 AM
E_ROCK
I really think a 9" as a builder axle. Can it be way stronger than a D44, of course. Can it be weaker in some cases, yes!. Really it depends on which ford 9" you get. If you have a non-nodular iron 3rd members, you can blow the third member apart with as little as 31" tires and lockers. It can be an easy fix though with just picking the right 9" from the bone yard. And really the stock 31" spline really aren't the strongest either. The stamped steel housing really can flex alot.
With that being said, I would love to have a trussed 9" stuffed with a truehi9 third member, a 35" spline locker, and 35 spline alloys.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #10 of 64 Old 04-01-2008, 08:27 AM
1 ton yj
1 ton yj's Avatar
9" all the way. Can be built to be as strong as a 60.
I'd build mine shaved, braced top & back and built with a Moser 3rd, 35 spl Detroit Locker, D70 tubes, spindles 35 spl shafts and FF hubs.
1 ton yj is offline
post #11 of 64 Old 04-01-2008, 10:01 AM
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
I know a guy who just built one just like that. Except he used sterling spindles and hubs. It's bad!
"Beat it like it owes you money"
Jeep Wrangler with some bolt-on "stuff"
Hokie_YJ is offline
post #12 of 64 Old 04-01-2008, 11:09 AM
1 ton yj
1 ton yj's Avatar
I'd use the D70 stuff because I can get a D70 for about what I could sell the gears on ebay for, and because the splines match those of a 9" detroit.
Got any pics of how your friend build his? What did he use to align the housing?
The parts I can come up with easily, I just don't have a lathe to make the alignment tools with.
1 ton yj is offline
post #13 of 64 Old 04-01-2008, 11:58 AM
OldFatGuy
I'd get the 9-inch just because it's so much easier to set up ring and pinion gears. Also, the steel housing makes it much more convenient to weld on trusses, etc.
OldFatGuy is offline
post #14 of 64 Old 04-01-2008, 01:41 PM
fratis
fratis's Avatar
Originally Posted by 1 ton yj View Post
9" all the way. Can be built to be as strong as a 60. .
can be built stronger. 60s are not the end-all axle the internet makes them out to be.
fratis is offline
post #15 of 64 Old 04-01-2008, 01:53 PM
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
He just used the sterling because that's what he had laying around. I don't have any pics, but i can ask him about what he did to align the housing.
Hokie_YJ is offline
Dana 44 / Ford 9 inch Swap into YJ garr79 YJ Wrangler Technical Forum 7 06-07-2010 07:38 AM
Dana 60 vs ford 9 inch bayvilleYJ YJ Wrangler Technical Forum 30 07-10-2007 10:04 PM
dana 44/60 OR dana 44/ford 9" (pics) Michael_94YJ YJ Wrangler Technical Forum 33 06-29-2007 06:44 AM
Ford 9 inch into a TJ? sickboy98tj TJ Wrangler Technical Forum 19 03-20-2006 03:25 PM
Dana 44 Front Ford 9 inch Rear Down&Dirty TJ Wrangler Technical Forum 2 08-30-2004 08:51 AM
