Ford 8.8 V6 or V8? - JeepForum.com
post #1 of 13 Old 05-02-2007, 11:53 PM Thread Starter
jeepfury
Ford 8.8 V6 or V8?
Ok I have decided that I will be shopping for a ford 8.8 for my YJ this weekend. I would like to know if there are any differences in an 8.8 out of a V6 exlporer or a V8 explorer? Do they all have 31 spline shafts after 96 as long as its out of an explorer? I am looking for 4.10's and the V6 8.8's are a lot easier and cheaper to come by so far. I searched and didn't find anything.
Thanks for any info
JOOP
00 Cherokee Classic- Stock
jeepfury is offline
post #2 of 13 Old 05-03-2007, 04:31 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Go to a Ford dealer and ask about it in general, and ask about part numbers for rear shafts for various models. Since I wouldn't intend to buy anything and it could take a while of his/her looking, I'd go there face to face rather than just call.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 13 Old 05-03-2007, 08:04 AM
stump buster
Junior Member
v6 if ya want 4:10 gears-
stump buster is offline
post #4 of 13 Old 05-03-2007, 08:09 AM
ZickZJ
There is no difference between a V6 and V8 axle. I do believe there is something different on the axle starting in 2001 and later though.
Also, V8 models had 4.10 gears as well.
Sold 90' YJ, 4.2, Weber, 4" Procrap, 33" BFG MTs, 8.8 w/ 4.10s & LSD, SYE & Tomwoods DS, Dual Optimas, Jacobs, Electric fan.
97' ZJ, SOLD
ZickZJ is offline
post #5 of 13 Old 05-03-2007, 08:31 AM
OhioYJ
All Explorers got the 31 spline shafts, doesn't matter which motor it got, or what year. Starting in 98 they started using bigger wheel bearings, I believe 98 was also the first year of the 7/8" crossshaft in the carrier, instead of the 3/4".
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things.
-- Mike
OhioYJ is offline
post #6 of 13 Old 05-03-2007, 02:17 PM Thread Starter
jeepfury
Thats good to hear from two different people. The junkyard must think a v8 axle is more valuable. I will be shooting for a 98 and up then.
JOOP
jeepfury is offline
post #7 of 13 Old 05-03-2007, 02:24 PM
pendleton
'95-'01 Explorer's had disc brakes, so look for them. '02 and later had a change to IRS, so they don't even have a solid rear axle. I found my axle off of craigslist. I put out a wanted add and got a couple of offers within a couple of days. I ended up with an '01 having factory 4.10's for $50. It's another option to try.
pendleton is offline
post #8 of 13 Old 05-03-2007, 02:41 PM Thread Starter
jeepfury
Also another quick question is the limited slip in the explorers a clutch type or a gear type?
JOOP
jeepfury is offline
post #9 of 13 Old 05-03-2007, 02:43 PM
ZickZJ
Clutch type
97' ZJ, SOLD
ZickZJ is offline
post #10 of 13 Old 05-03-2007, 04:17 PM
pendleton
Originally Posted by ZickZJ
Clutch type
The application for the axle should determine the carrier you eventually use. The Limited Slip found in the 8.8 is known to be a bit on the weak side for heavy abuse, where the open carrier is more stout in design. If you want to keep the limited slip, you can buy a high performance rebuild kit for it which stiffens up the action and supposedly keeps it from wearing out as quickly as normal. I think the rebuild kits are $30 or $40 dollars. If you have the choice between an open carrier and LSD on the axle you buy, you might want to pick up the LSD, even if you do not want to run it. Alot of the FORD racing guys like these and will pay upwards of $150 for the LSD carrier while an open carrier is much cheaper to replace it with.
post #11 of 13 Old 05-03-2007, 06:40 PM
Cobra Jeep
Yep, it doesnt matter as long as it is a 95 or newer. Mine came from a 96 2wd exploder with the V6. It has 3.73's and the limited slip.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #12 of 13 Old 05-03-2007, 06:52 PM
red87yj
red87yj's Avatar
1987 YJ Wrangler
make sure that you know what an 8.8 looks like. im not 100% sure, but i know i read somewhere that an explorer came with a dana 35... maybe a base modle, i could be wrong, but in my research i remeber reading that. anyway just make sure you know what it looks like. go to the U Pull it yards they only look at the lugs on it. the whole axle cost me 50 bux. that was disk to disk. check out the gear oil in the yard see what you are buying before you get it.
later
Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline
post #13 of 13 Old 05-03-2007, 08:07 PM
mighty4banger
^ D35 in the FRONT.
The rear is an 8.8
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford SVO disk brake kit on Ford 8.8 texashoghunter TJ Wrangler Technical Forum 0 07-10-2008 07:12 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
Ford 8.8 topfuel83 TJ Wrangler Technical Forum 3 03-16-2007 06:56 AM
Ford T18 and Ford Dana 20 JOKER4INK YJ Wrangler Technical Forum 0 11-23-2005 05:00 PM
