Ford 8.8 swap or regear question - JeepForum.com
post #1 of 5 Old 09-16-2011, 06:07 PM Thread Starter
dougbrown
Hi guys,
I want to do away with my 3.07 gears in my jeep. I was just going to swap to a Ford 8.8 rear with 4.10 and find a Dana 30 front a 4cyl yj.
Now what do I need to do to swap a Ford 8.8 under there and what are the best years to look for one. I know it has to come from an explor.
Now I'm assuming 4.10 would be the best gear ratio. I want to be able to get ok mpgs and do 65 to 70 on the highway and use 5th gear. 1 threw 3rd and sometimes 4th sucks.
dougbrown is offline
post #2 of 5 Old 09-16-2011, 06:12 PM
notmyj
Here is a current thread that should answer some questions for you...
http://www.jeepforum.com/forum/f12/s...-35-a-1264604/
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 5 Old 09-16-2011, 06:18 PM Thread Starter
dougbrown
Thanks! for the link but I want to get a ford 8.8 from a junk yard and drop it in. Not one from a shop for 900 bucks!
post #4 of 5 Old 09-16-2011, 06:37 PM
klrstew
Here you go. Before I decided to grab ankles and order one,
I dug up a bunch of valuble info. Check these out. Should
answer even questions you didn't think of.......lol
Good Luck!
http://www.jeepsunlimited.com/forums...d.php?t=371713
http://www.therangerstation.com/tech_library/Axles.html
http://members.cox.net/rough-riders/...8/ford8_8.html
http://www.jedi.com/obiwan/jeep/ford88.html
klrstew is offline
post #5 of 5 Old 09-16-2011, 07:43 PM
I8AHUMR
I did what you're thinking on mine and have no complaints. HP 30 from a four cylinder with Tj one piece shafts and 8.8, both 4.10. Look for a 95-01 explorer and a 95 HP30 if your not doing one piece shafts. That year has the larger front ujoint. Found both of mine on WWW.car-part.com. Maybe car-parts? There's a nice install kit from WWW.knowwhere2jeep.com. I went with the Ubolt flip kit. You'll need to weld the spring perches and shock mounts. Anymore ??'s. Pm me if you want specifics and/or pictures.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
4.0HO to Ford 19# injector swap question Krochus YJ Wrangler Technical Forum 2 02-13-2011 07:01 PM
Ford 8.8 rear axle swap question tha_Toad TJ Wrangler Technical Forum 3 08-08-2010 06:58 AM
almost completed Ford 9" swap... Got a question Apollo12227 YJ Wrangler Technical Forum 6 02-27-2010 12:59 AM
Seat Swap Question - Ford Explorer Shanes92YJ YJ Wrangler Technical Forum 0 01-11-2010 08:12 PM
REGEAR Question on Ford 8.8 daddoty YJ Wrangler Technical Forum 21 07-26-2006 02:02 AM
