ford 8.8 swap in my 90 yj first time swap helpp!! - Page 2 - JeepForum.com
post #16 of 27 Old 04-18-2012, 10:19 PM Thread Starter
LIjeep631
thanks now you run the xj shaft with the sye or with the stock yoke ?
LIjeep631 is offline
post #17 of 27 Old 04-19-2012, 04:54 AM
'92 vegas YJ
X4 on running an xj shaft
Run it with a SYE
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #18 of 27 Old 04-19-2012, 10:06 AM Thread Starter
LIjeep631
thanks man
post #19 of 27 Old 04-19-2012, 02:06 PM
janders82
2010 JK Wrangler
what years of XJ front shafts fit?
will the XJ front shaft link up to the D35??
janders82 is offline
post #20 of 27 Old 04-19-2012, 02:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's all xj's and some zj's iirc. And I believe they're 1310 and your driveshaft yoke is 1330 so grab an adapter ujoint from autozone at $13.
Luck Favours The Prepared
Anticanman is offline
post #21 of 27 Old 04-19-2012, 02:53 PM
ruthole
The brake lines gotta be changed out or will they go to the Ford axle?
94 yj, 4" RC lift 1" shackles, 33's interco M/T's, SRC front bumper, custom built rear bumper, cb, Hi-lift, D30 OX locker, 8.8 LSD,
Lone jeep club member #1
Originally Posted by TMSquy View Post
If parts aint flyin you aint tryin!
ruthole is offline
post #22 of 27 Old 04-19-2012, 02:57 PM
'92 vegas YJ
youre DS should be 1310(some are 1330 so you gotta check) and the 8.8 is a 1330. you could either buy the 1310 adapter for the 8.8 or get a 1310/1330 Ujoint.
i went the latter route because the driveline shop i went to didnt have a 1310
adapter and i didnt want to wait for what if i ordered it
post #23 of 27 Old 04-19-2012, 04:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The dana 35 from mid '93 and up uses the larger joints. I was a little off but was typing from a tractor.
post #24 of 27 Old 04-19-2012, 09:19 PM
lutzke21
As far as brakes, I cut down and re-flared the jeep hard lines, re-bending them to match the new axle. The vent/distribution block mounts in the axle without an issue, at least in my case. I purchased two new passenger side brake hoses with banjos bolts that connect at the ends of the jeep lines, bolted onto a bolt I welded at either end of the axle. This is my first attempt at brakes (and double-flares, sheesh). Many people just buy new, pre-flared hard lines in the lengths they need, so that's an option as well.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #25 of 27 Old 04-21-2012, 05:38 PM
ruthole
My block bolts onto a bracket on the side and the vent hose is seprete from the block.
ruthole is offline
post #26 of 27 Old 02-18-2014, 11:32 PM
chris94
I have a 92 jeep yj and iam doing the 8.8 swap and what adapter do I need and were can I buy one autozone dont have it. advance either
chris94 is offline
post #27 of 27 Old 02-19-2014, 05:11 AM
StanF
East Coast Gear Supply
or a million other sources - just google "ford 8.8 1310 flange"
StanF is offline
Ford 4.6L vs 5.0L V8 swap spiderman637 TJ Wrangler Technical Forum 105 06-22-2012 06:45 AM
Ford 8.8 Swap LandonW TJ Wrangler Technical Forum 6 06-07-2011 04:48 PM
Ford 8.8 swap Jacola11 TJ Wrangler Technical Forum 4 06-22-2010 02:58 PM
Ford 8.8 swap millersjeeps TJ Wrangler Technical Forum 5 03-23-2008 07:44 AM
Another Ford swap.... Bulldog1 YJ Wrangler Technical Forum 0 04-03-2007 08:20 PM
