ford 8.8 rear dana 30 front - JeepForum.com
post #1 of 34 Old 09-05-2012, 09:07 PM Thread Starter
highenergy
Im thinking about putting an 8.8 in my 95 yj. Wondering how to go about it.
Regearing the front?
410?
Bryan Urben
highenergy is offline
post #2 of 34 Old 09-05-2012, 09:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Anticanman is offline
post #3 of 34 Old 09-05-2012, 10:55 PM Thread Starter
highenergy
Regearing the front, is that difficult?
Bryan Urben
post #4 of 34 Old 09-05-2012, 10:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes it's difficult but may be easier than finding a 4cyl Yj Dana 30 in your area. Start pounding pavement and find one that's geared from the factory.
Luck Favours The Prepared
post #5 of 34 Old 09-06-2012, 05:54 AM Thread Starter
highenergy
What I gather from that is that it is almost easer to replace both? The 4cil came with 410? Thanks for the help
Bryan Urben
post #6 of 34 Old 09-06-2012, 06:39 AM
Jeepsr4me
I can take on just about any project related to a jeep BUT gears. I just dont have the tools to do it correctly.
So I farm out all gear changes to a local drivetrain repair place. I take the axle out and pressure clean it real good. remove the guts of the diff and clean in there too. I pop all the seals and get them a clean housing. They charge me 80-150 to set up a new set of gears most times. I also tell them I am in no hurry so they can work on it when they can.
Jeepsr4me is offline
post #7 of 34 Old 09-06-2012, 06:49 AM Thread Starter
highenergy
The search starts there are a lot of jy around me so I will make some calls. Thanks again
Bryan Urben
post #8 of 34 Old 09-06-2012, 06:59 AM
Louie4
"You pass butter"
Louie4's Avatar
I found my 8.8 with 4.10's which was a relief. This was after I geared my D35 and D30 to 4.10's myself. I should have never put the money into the D35 but you live and learn.
As far as gears go they are more tedious and require some tools but I think a seasoned backyard mechanic can do it with enough research and preparation. Hell, I was able to to do it so I'm sure most can
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #9 of 34 Old 09-06-2012, 07:04 AM
FreedomJeeps
I love my 8.8!
FreedomJeeps is offline
post #10 of 34 Old 09-06-2012, 12:38 PM Thread Starter
highenergy
Is there a website to buy new gears for the 35?
Bryan Urben
post #11 of 34 Old 09-06-2012, 12:54 PM
crackedcornish
why do you want to put gears in the D35?
these guys have everything you need for a 8.8 and D30 combo...and they have gears for a D35 if you really want them.
http://eastcoastgearsupply.com/i-476...-assembly.html
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #12 of 34 Old 09-06-2012, 01:05 PM Thread Starter
highenergy
Sorry I ment the 30. Thanks for that website.
Bryan Urben
post #13 of 34 Old 09-06-2012, 01:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You can talk to whomever you're going to have put the gears in for you about buying them assuming its a shop. Either way, going from 3.07-4.10 will require a new carrier and I would suggest purchasing one that isn't openable open differential. There are lots of options out there on the market including the selectables or even a Detroit Autolocker which both would fare well with the CAD still in place.
Just think long and hard about your next two moves before you make your current move. Building a jeep is a lot more like chess than Legos.
post #14 of 34 Old 09-06-2012, 02:23 PM
exige05
Damn if the op was closer I have a set of 410 ring and pinion for a Dana 30 and 35 im just looking to unload cheapish. I chose not to regear my front and just have an 8.8 set up to 3.07s.
exige05 is offline
post #15 of 34 Old 09-06-2012, 02:45 PM
Kraxen
Depending on what axles go for in your area, (around here i can buy any front axle for $67 and any rear axle for $32 from a local u-pull it yard) it would most likely be cheaper and easier to find a D30 from a 4 cylinder jeep and swap it in then buying new gears and paying someone to do it for you. And while having the axle out of a jeep you can clean it up, paint it and replace whatever you feel is necassary before installing it.
Then you can probably sell your original axle and break even or maybe even make a buck or two.
92 YJ
95 YJ
Kraxen is offline
1978 ford F250 Dana 60 front/Rear spawnofsatan YJ Wrangler Technical Forum 13 02-25-2012 09:34 AM
ford dana 35 front starry5150 TJ Wrangler Technical Forum 11 07-06-2008 07:31 PM
ford front hp dana 44 JERSEYYJ YJ Wrangler Technical Forum 9 11-11-2005 11:19 AM
Dana 44 Front Ford 9 inch Rear Down&Dirty TJ Wrangler Technical Forum 2 08-30-2004 09:51 AM
Where can i get a HP Dana 44 front, and a ford 9" rear, w/ same width+lug pattern? jeepcj7 TJ Wrangler Technical Forum 7 11-25-2003 03:54 PM
