Quantcast Ford 8.8 Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ford 8.8 Questions
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 04-24-2009, 08:01 AM   #1
Towny72
Ford 8.8 Questions
Well as the group has pointed out to me the 8.8 is going to be my best option for a rear axle swap in my 94YJ. I am still going to look around for a month or so for that white whale XJ D44.... But I bet I'll end up with the 8.8. So anywho my questions are how avail are aftermarket parts for this axle. New upgrade shafts, gears, dif covers. And my second big question would be is this axle as strong or stronger then the D44?
Thanks
Bob
My friend just got a JK, he asked me whats the JK for.... I said "Its a jeep, Just Kidding"
Towny72 is offline   Reply With Quote
Old 04-24-2009, 08:27 AM   #2
wendell
1987 YJ Wrangler
Yep, there's all that stuff in the aftermarket. However the explorer 8.8 is pretty stout out of the box with 32 spline axles, big bearings and what have you. I think it's stronger than the 44.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
Old 04-24-2009, 09:35 AM   #3
1998zj
It has 31 splines, and yes it is pretty stout.
1998zj is offline   Reply With Quote
Old 04-24-2009, 10:09 AM   #4
Mean Max
Mean Max's Avatar
Look on the driver's door of the Ford Explorer donor vehicle for the axle code on the VIN sticker.
Explorer 8.8 Axle codes
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Specs:
Code Capacity Ratio
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
L - Limited Slip Differential
C - Conventional Differential
Code Ratio
41 3.27
43 3.08
42 3.45
44 3.73
45 3.55
47 4.10
72 3.08C
74 3.45C
82 3.08C
84 3.45C
85 3.55C
86 3.73C
87 4.10C
89 (1992-1998) 4.10C
89 (1999-2001) 4.56C
91 3.27C
92 3.08C
95 3.55C
96 3.73C
97 4.10C
F4 3.45L
F5 3.55L
F6 3.73L
F7 4.10L
K6 4.10L
D2 3.45
D4 3.73L
D7 4.10
R5 3.55L
R6 3.73L
R7 4.10L
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 04-24-2009, 10:16 AM   #5
fyrdriver
Look under FAQ there a write up on this. But here is some of it.
The axle shaft strength (tested by Warn Ind.) is as follows:
F8.8= 6,500 (lb. ft.)
D44= 4,600-5,000 (lb. ft.)
D35C= 4,000-4,300 (lb. ft.)
COT: Continuous output torque rating
MOT: Maximum output torque rating
Numbers from January edition of Fourwheeler, page 60.
Dana 35 rear axle COT: 870 MOT: 3480
Dana 44 rear axle COT: 1100 MOT: 4460
Ford 8.8 28spline COT: 1250 MOT: 4600
Ford 8.8 31spline COT: 1360 MOT: 5100
Dana60 semifloat COT: 1500 MOT: 5500
Measurements:
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188”!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width* 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
Hole diameter for ABS sensor in top of housing: .811".
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
*Explorer & Mountaineer.
(The F-150 8.8 is drum brake and width WMS to WMS is 65.5”.)
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jeep_Club
fyrdriver is offline   Reply With Quote
Old 04-24-2009, 10:49 AM   #6
miwoodar
How does one determine which option is right for a particular YJ?
Also, does the master cylinder need to be replaced when switching to an 8.8 with disks?
miwoodar is offline   Reply With Quote
Old 04-24-2009, 10:52 AM   #7
Poke
Poke's Avatar
the stonger one
mild mechanic that's overly ambitious
Jeep Envy
Originally Posted by Hashbrown View Post
The trouble with running is...by the time you realize you're not in shape for it, it's too far to walk back.
Complete YJ Besttop with hardware for sale. PM me.
Poke is offline   Reply With Quote
Old 04-24-2009, 10:58 AM   #8
Mean Max
Mean Max's Avatar
Get a 31 spline from a '95-'01 (disc brakes) or a '91-'94 (drum brakes) Ford Explorer. Look at the codes to select the gear ratio & differential type (open or LSD) you want/need.
Most people don't, but brake upgrades are ALWAYS a good idea!
Max
Old 04-24-2009, 12:14 PM   #9
timatoe
Jello Puddin'
timatoe's Avatar
ALL, exploder axles will be 31 spline, just get one there drum or disk your option.
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Old 04-24-2009, 07:13 PM   #10
Towny72
Very nice guys. Looks like that 8.8 will handle anything I ever run in this rig. I never see going bigger then 33's or the swamper 34*9.50s But yes if I want to regear I just need to find the 42axle which is the 4:10 gears.... Love it . ... Thanks again
Old 04-24-2009, 07:14 PM   #11
Towny72
Hey is the diff neck longer then the D35. Reason I ask is I am already lifted which has pulled my drive shaft back a bit so I have some room to play with if its longer then the 35, if its shorter I may be cutting it close...............
Old 04-24-2009, 07:59 PM   #12
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
IIRC, the 8.8's diff snout is ~1" longer by the time you install a flange adapter.
If you wish - I can go out to my garage & check for the snout measurement.
Just let me know if you like that measurement. Heck, I need to get up & grab a beer anyways.
Joe Dillard is offline   Reply With Quote
Old 04-24-2009, 08:11 PM   #13
Joe Dillard
Measureing from the center of the axle tube - I get 11.625" to the center of the rear-most ujoint.
Here's how I measured it:
3.25" (axle tube diameter) X .5 (centerline) = 1.625" + 10" from the outside forward of the axle tube to the centerline of that rear ujoint = 11.625".
Old 04-24-2009, 09:03 PM   #14
Towny72
Hey Joe, did you grab me a cold one while you were at it.... Didnt think so, thanks for leaving a brother hanging....... Hey man all kidding aside thanks for the measurements.
Now I guess i need to find a #42 8.8 axle and get some perches etc.....
Old 04-24-2009, 09:31 PM   #15
Joe Dillard
Of course I did - it's Friday night.
Glock Forum
