ford 8.8 questions - JeepForum.com
post #1 of 18 Old 03-22-2007, 03:50 PM Thread Starter
demoguru
ford 8.8 questions
I am sure it is on here somewhere. But can someone either tell me or direct me to the proper posting or site. I have a ford 8.8 out of a 94 explorer and want to put it in my 90 yj. Do they sell a kit or do I have to but just a new set of leaf perches. Will I need a new driveshaft? I know it is a drum rear end, and I am ready to hadle that til later. What all do I need to put this in my jeep?
demoguru is offline
post #2 of 18 Old 03-22-2007, 03:51 PM
bayvilleYJ
I would like info on this subject too. Finally think i killed the d 35.
bayvilleYJ is offline
post #3 of 18 Old 03-22-2007, 03:52 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
2nd this week i believe......
see on the bottom of the page, where it has page numbers?? go thru the pages, there will be @50 threads on the 8.8.
or foot the bill for membership and then you can just search, or maybe, even.............
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 18 Old 03-22-2007, 05:00 PM
YJ-Mike
Gotta agree with Martin, google is your friend, or just go through a couple of prior pages and you will find many threads on 8.8 installs.
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #5 of 18 Old 03-22-2007, 05:22 PM
Yarz
Yarz is offline
post #6 of 18 Old 03-22-2007, 07:28 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
have a look here:
http://www.jeepforum.com/forum/showp...4&postcount=13
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #7 of 18 Old 03-22-2007, 11:41 PM
RockWoRM
RockWoRM's Avatar
Read up on the links everyone posted. Here's a couple pics that might help since you've got a drum, as do I.
I saved the YJ e-brake coupler and lengthed it to fit because the 8.8 drum lines were shorter.
added some SS braided line to the 8.8 rubber flex line so it would reach the frame rail.
used JKS u-bolt plates, Warrior shock mounts, TKHfab diff. cover, and welded the tubes. U can also see the SYE/CV in there.
hope that helps
WoRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #8 of 18 Old 03-23-2007, 11:07 AM
bayvilleYJ
Did you guys do the gears yourself? I'm a little nervous about doing gears , but i dont want to pay a fortune to have it done for me.
post #9 of 18 Old 03-23-2007, 11:21 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i had the gears done in the shop on mine. $250~ labor for the install.
post #10 of 18 Old 03-23-2007, 11:54 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
^^^That's $ well spent IMO.^^^
Joe Dillard is offline
post #11 of 18 Old 03-23-2007, 12:20 PM
bayvilleYJ
So I'm guessing around 700 bucks for the whole swap?
post #12 of 18 Old 03-23-2007, 12:25 PM Thread Starter
demoguru
thanks for the pics. and the links
demoguru is offline
post #13 of 18 Old 03-23-2007, 12:47 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
  • $250 axle
  • $250 gear install
  • $200 gears and install kit
  • $30 brake line parts
  • $40 flange adapter
  • $100 wheel spacers
  • $700 ARB
it depends what you want to do with it.
post #14 of 18 Old 03-23-2007, 12:59 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
  • $250 axle
  • $250 gear install
  • $700 ARB
I liked how you throw the ARB in there like it isn't an option.
atomicmoose is offline
post #15 of 18 Old 03-23-2007, 01:20 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
well, there are lots of options.
that is just my point, you can do whatever you want with it.
mine for example has all of the above listed things+
  • shaved and plated
  • trussed
  • custom mounts
  • custom shock mounts
  • welded tubes
  • super 88 axles with c clip eliminator
  • bla bla bla.
what is the budget we are working with on these 8.8 installs?
what sort of pounding do you have in mind for it?
Ford 8.8 few questions ChevyBlazerBoy YJ Wrangler Technical Forum 5 05-19-2009 09:56 AM
Ford 8.8 Questions Towny72 YJ Wrangler Technical Forum 17 05-08-2009 03:09 PM
A few Ford 8.8 questions JeSimmers TJ Wrangler Technical Forum 36 11-12-2008 09:01 PM
Ford 8.8 Questions? Wishin TJ Wrangler Technical Forum 9 09-26-2005 02:02 PM
Ford 8.8 questions BudmanV6 YJ Wrangler Technical Forum 14 03-19-2005 03:16 AM
