Quantcast ford 8.8 questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > ford 8.8 questions
Old 09-06-2010, 03:56 PM   #1
wordo30
ford 8.8 questions
I was thinking about putting a new rear end in my jeep and i was reading some posts and some people said that you couldn't do this swap if you have a CV driveshaft bc the diff is not centered. is this true?
wordo30 is offline   Reply With Quote
Old 09-06-2010, 04:14 PM   #2
4.7stroker
4.7stroker's Avatar
In short no it is not true.
Dwayne
4.7stroker is offline   Reply With Quote
Old 09-06-2010, 04:18 PM   #3
SLADE
Driveshafts have a 360 degree operating range. The pinion can be up, down, right or left. It doesnt matter as long as the pinion is within the operating range of the driveshaft. The 8.8 has a very small offset (2"+-), so it will not be an issue.
SLADE is offline   Reply With Quote
Old 09-06-2010, 06:33 PM   #4
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
Go ahead and post the links to those threads.
Also, whoever posted that garbage is 100% wrong I wouldn't listen to a thing they said.
Thousands upon thousands of folks have did it with a CV drive shaft. I have lost count with how many I have helped do.
Joe Dillard is offline   Reply With Quote
Old 09-06-2010, 06:38 PM   #5
Mean Max
Mean Max's Avatar
I agree wholeheartedly!
I just did the wife's last week and it has a CV shaft with an SYE kit installed. I actually did a better job on setting the pinion angle this time around, and it's smoother than ever.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 09-06-2010, 07:50 PM   #6
timatoe
Jello Puddin'
timatoe's Avatar
Like these guys have already said, there's no truth to what you've previously heard. I'd venture to say that a large majority of people running a 8.8 do run a CV shaft.
timatoe is online now   Reply With Quote
Old 09-06-2010, 08:11 PM   #7
stanimals2
Can someone please post what mods. and how to to change to the 8.8 in a 94 Wrangler . I need to either change mine or repair the one in mine and Mad Max has posted in my earlier post that it could be done.
Thanks, Stan
stanimals2 is offline   Reply With Quote
Old 09-06-2010, 08:19 PM   #8
Mean Max
Mean Max's Avatar
Originally Posted by stanimals2 View Post
Can someone please post what mods. and how to to change to the 8.8 in a 94 Wrangler . I need to either change mine or repair the one in mine and Mean Max has posted in my earlier post that it could be done.
Thanks, Stan
There, I fixed it for you!
Okay here the cliff notes on a 8.8 swap.
1) Determine your axle ratio
2) Determine what axle code 8.8 you need to match your front axle
3) Locate an 8.8 axle & cut the sway bar mounts & spring perches off
4) Loosely bolt 8.8 into your Jeep, set pinion angle, tack spring perches onto axle tubes
5) Remove axle & completely weld the perches in place
6) Fabricate, buy, or cut off & reuse your old shock mounts & weld them in place
7) Plumb & bleed brakes
8) Use a pinion flange from a Ranger on the rear U-joint that will accept your 1310 U-joint
Max
Old 09-06-2010, 09:58 PM   #9
wordo30
I thought I had read something about that but apparently not. They run the 5x4.5 bolt pattern on those right?
Old 09-06-2010, 10:02 PM   #10
Mean Max
Mean Max's Avatar
Yes.
The '95-'01 Explorer 8.8 will get you disc brakes, 31 spline axles, and the 5 on 4.5" bolt pattern.
It's 1-1/4" narrower than the Dana 35 (5/8" on each side) which turns out to be such a small amount that you won't notice.
Max
Old 09-06-2010, 11:16 PM   #11
wordo30
cool thanks
Old 09-07-2010, 12:46 AM   #12
Joe Dillard
You can save yourself a lot of headaches by reading the FAQ (Frequently Asked Questions) Sticky thread.
Once you click on it - on the first post & the first line, there's a link, click on that.
Now scroll to post #11 and you'll find all sorts of 8.8 info.
http://www.jeepforum.com/forum/f12/yj-frequently-asked-questions-faq-write-ups-find-your-answers-here-580536/
Old 09-07-2010, 08:45 AM   #13
wordo30
ok thanks.
Old 09-07-2010, 09:28 AM   #14
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Agreed, the slightly shorter is not a problem. I ran that way for a long time.
When I added the Warn hub conv kit to the front though, it wasn't pretty. The Warn kit made the front 1" wider/side, then the 8.8 made the rear 5/8" narrower/side. I found I couldn't track well at all on some stuff in the woods. I'd plant a front tire and the rear would track off enough to not be nice, fall off a ledge or whatever. I decided to use 1.25" spacers on the back, which has been fine. Agreed though, completely not needed with with stock width front, and the 8.8 diff offset is a don't care too.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers
JeeperDon is offline   Reply With Quote
Old 09-07-2010, 09:33 AM   #15
Mean Max
Mean Max's Avatar
From what I understand, the Super 8.8 kit increases the width by 1" overall, so someone put off by the narrower width may want to keep that in mind too.
Max
Glock Forum
