Ford 8.8 and other Questions.. I know, it's been asked before. - JeepForum.com
post #1 of 7 Old 07-19-2007, 10:13 AM Thread Starter
denwagh
I'm sure this is buried someplace on the forum but after several searches I couldn't find what I'm looking for so I invoke the gurus once more....
I've got a 93 YJ. I want to do an 8.8. I know that the shock mounts have to be re-welded.. So.. I have a few questions...
1) Other then remounting the shock mounts, what else needs to be done? Can I re-use the old shock mounts or do they make after market?
2) Do I need to look for a certain 8.8 that the stock drive shaft will fit or is it the same spline?
3) Gears.. I cannot see a plate on my front or rear diff covers to tell me what I have.. I've read the faq, but I want to be certain.. Is there another way, counting the teeth perhaps?
4) Disk vs Drum.. I've heard of people not getting good stopping power with disk using the stock Jeep braking system.. Anyone have experience?
5) I'm guessing the wheel bolt pattern is the same as stock jeep?
6) Any other "Gotcha's" I should watch for?
Thanks guy, you are always a great help.. Without this forum I'd probably still be under my Jeep trying to figure out how to replace a clutch..
denwagh is offline
post #2 of 7 Old 07-19-2007, 10:27 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The very first consideration is whether you are going to be SUA, SOA, or linked. This makes a big difference on how I feel or recommend it be set-up.
I can answer all your questions, but instead of giving two or three different answers for some of your questions due to not knowing axle placement I'd rather not type three or four versions.
Joe Dillard is offline
post #3 of 7 Old 07-19-2007, 10:28 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
atomicmoose is offline
post #4 of 7 Old 07-19-2007, 10:29 AM
atomicmoose
Just call me Moose
I knew Dillard would preempt me. LOL
post #5 of 7 Old 07-19-2007, 11:25 AM Thread Starter
denwagh
I will probably stick with SUA on this rig.. It's my daily on 33's with a tiny body like and a Superlift spring kit.. I like the height and other then mud, don't do any climbing in it...
denwagh is offline
post #6 of 7 Old 07-19-2007, 11:28 AM Thread Starter
denwagh
Thanks! .....
denwagh is offline
post #7 of 7 Old 07-20-2007, 11:46 AM
ZickZJ
1) Other then remounting the shock mounts, what else needs to be done? Can I re-use the old shock mounts or do they make after market? I'm sure if you could make the stock mounts work if you don't destroy them during the removal process. Or just pickup a new set for about $20.
2) Do I need to look for a certain 8.8 that the stock drive shaft will fit or is it the same spline? All 8.8s have a flange adapter with a U-Joint adapter bolted to it. Whether or not your U-Joint fits this adapter is a different story. Mine did but others had to buy a new U-Joint. Also your driveshaft length may not work depending on your setup.
3) Gears.. I cannot see a plate on my front or rear diff covers to tell me what I have.. I've read the faq, but I want to be certain.. Is there another way, counting the teeth perhaps? Marking the driveshaft and tire and then spinning the tire to see how many turns it take to make the driveshaft spin around once. I'm sure there's better explanations out there for this than mine.
4) Disk vs Drum.. I've heard of people not getting good stopping power with disk using the stock Jeep braking system.. Anyone have experience? Mine has disc's and the entire brake system is still stock and I'd say it stops just the same as the old drums, maybe even a little better.
5) I'm guessing the wheel bolt pattern is the same as stock jeep? Yes
6) Any other "Gotcha's" I should watch for? Brake lines, how your going to connect them to your current setup. Mine I just bought two passenger side rubber lines that go into the calipers and them made up some hard line to connect to the drop down line coming from the frame.
Also emergency brake lines too if you plan on using it.
This message is not too short.
Sold 90' YJ, 4.2, Weber, 4" Procrap, 33" BFG MTs, 8.8 w/ 4.10s & LSD, SYE & Tomwoods DS, Dual Optimas, Jacobs, Electric fan.
97' ZJ, SOLD
ZickZJ is offline
► YJ Frequently Asked Questions (FAQ), Write Ups & stock specs. Look here first rustywrangler YJ Wrangler Technical Forum 13 10-07-2010 12:00 PM
Jeep JK - Frequently Asked Questions NaeKid JK Wrangler Technical Forum 9 07-23-2010 10:29 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
ford 8.8 questions demoguru YJ Wrangler Technical Forum 17 03-23-2007 08:05 PM
Ford 8.8 Questions emcee5000 TJ Wrangler Technical Forum 1 05-16-2005 09:16 AM
