Ford 8.8 locker and gear ratios - JeepForum.com
post #1 of 4 Old 06-04-2002, 11:25 AM Thread Starter
bighair
Hey guy's,
Lockers replace all the spider gears in the carrier. do you somehow put your spider gears into the locker? reuse them, or does the locker completely replace the gears? and you no longer need the gears?
If you put your spider gears into the locker, I'm looking for a 4.10 ration for a Ford 8.8".. I curently have 3.55 but they do not match with my front.
Please help
Thanks
Team Mod Squad
We are here to help YOU!
bighair is offline
post #2 of 4 Old 06-04-2002, 11:40 AM
moabster
moabster's Avatar
2011 WK
Hi,
The spider gears and carrier are replaced when you put in the locker. The gear ratio refers to the Ring and pinion gears. The Ring gear bolts onto the Carrier and the pinion connects to the drive shaft. Here is a URL that explains how it works pretty well:
<a href="http://www.howstuffworks.com/differential.htm" target="_blank">How stuff works - differentials</a>
Some of the links from this site have pretty good diagrams as well.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 4 Old 06-05-2002, 06:06 AM Thread Starter
bighair
Thansk Moabster.
it's all good now.. hehe now I have to find a R & P 4.10 ratio for a ford 8.8.. no yards around here want to separate the gears from the axles. hehe
Team Mod Squad
bighair is offline
post #4 of 4 Old 06-05-2002, 09:35 AM
Prime Lord
Prime Lord's Avatar
Location: Chesapeake, VA (My office is just hell w/ florescent lighting)
I wouldnt buy used gears but thats just me....Summit racing sells Ford Motorsport 4.10's for the 8.8. They run about $170. Those are the ones I would get. Being a Ford guy, I can tell you that they know what they're doing when it comes to this stuff.
As far as the locker....If you get a powertrax (lock-rite or no-slip) it just replaces the spiders. If you get an ARB, Ox, or Detroit it replaces EVERYTHING including the carrier.
~Jay
, 4.0, 5-speed. 1" Daystar Body Lift, 31x10.50 Goodyear MT/R's, CJ Style (87-91) Roll Bar, ARB Safari Snorkel, K&N Panel Filter, Dynomax SuperTurbo Catback. Still hunting for TJ Sahara flares!!!
, Maximum Motorsports: Rear LCA's, 4-point K-Member brace, & Std Length Subframe Connectors, FRPP 'C' Springs, Mac Pro-Chamber, Chrome BBK equal length shorties, B&M Ripper w/ leather cobra knob.
Prime Lord is offline
What gear ratios does TJ D44 came with? jzmtl TJ Wrangler Technical Forum 12 04-08-2007 10:33 AM
gear ratios mikemac4 YJ Wrangler Technical Forum 4 12-18-2005 06:24 PM
gear ratios JeepsKillAll TJ Wrangler Technical Forum 4 12-17-2003 04:29 PM
What is the gear ratios? and more. TheHerald YJ Wrangler Technical Forum 2 08-25-2003 10:22 AM
Gear Ratios raZe YJ Wrangler Technical Forum 1 03-07-2003 09:37 AM
