Ford 8.8 with drum brakes. Worth it?
| Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road | Black Magic Brakes - 5% Off, No Minimum Purchase Required |
#1 | |
I found a really good deal on a Ford 8.8 to swap into my '95 YJ. ($50 less than the U-pull it junk yard)The axle is out of a '91 Explorer and has drum brakes and a lock right. He says it needs new brakes and a new ring and pinion. That really isn't not a big deal to me seeing as I am going to have it re geared and I was already planning on new brakes.
My question is: Is it worth it to get an 8.8 with drum brakes? Or should I wait and get one with disc brakes?
Green 95 YJ. 2.5L Low output. 2.5" RE lift. 1.25" shackles. 33" BFG Mud Terrains.Build Thread (SOLD)
Jeep #2: Green '98 TJ 4.0L|AA SYE, Tom Woods shaft|4.88s|3" teraflex lift|2" BB|1.25" BL|1" MML|35" BFG All Terrains|Warn XD9000i| Build Thread Daily Driver: 1991 Ford Escort, white w/ graffitti stencils "I will never understand why people will spend money on huge rims with skinny tires when you can get small rims (15") with huge tires." "I'm teaching my jeep to roll over, so keep your distance." |
#2 |
for 50 bucks why would go with drums over discs?
if the pinion is shot what else is wrong? i'd pass big time. |
#3 |
^ I 2nd that statement. If you are going to have it regeared anyway, there is hardly a savings in $50 bucks.
The only benefit is that it already has a LockRight in it.... but since the R&P is bad, who's to say that there isn't something wrong with the locker too? $50 bucks is worth piece of mind to me. |
#4 |
Junior Member
Id pass, other then the increased strength the disc brakes are a definitive +
#5 |
Got my eye on you.....
I would pass.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#6 |
XJ on 37's
What are you going to regear to?
I would spend the extra $50 myself too. Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#7 |
i am regearing to 4.88
#8 |
Pass on it and get a 8.8 with 4.11 gears and dics brakes. Might even save some money.
MIKE http://www.dav.org/ MJM Powder Coating Elizabethtown Ky. http://www.cityprofile.com/ |
#9 |
I just read that most of the 8.8's with drum brakes have 28 spline shafts and not 31. Thank you everyone for talking me down. I may have found another out of a '98 with disc brakes.
#10 | |
Free clues & suggestions
ALL, I repeat, ALL, Explorer style stock 8.8's ALL have 31 spline axle shafts & carriers. None came different from the factory. None - zip - nada - ziltch - wala - zero. If you doubt me - try surfing 100's of websites that sell Explorer axle shafts, carriers/lockers (Explorer ONLY). Then find even 1 that advertizes a different STOCK spline count than 31. I have a feeling you'll be looking for a loooooooooooooooooooooooooooong time. ![]() |
#11 | |
ISO 9001 Compliant
I would not be afraid of drum brakes but if the gears are broken I would be afraid of a bent or spun tube.
. . "The right to be heard does not necessarily include the right to be taken seriously." —Hubert Humphrey . If you live within wheeling distance of San Diego county, click here |
#12 | |
#13 |
I agree - I wouldn't buy it either. As a matter of fact - with that type internal damage, I wouldn't take it for free, even if I was looking for one.
#14 |
Just for the record if the R&P was good and the correct gear I would go for a drum brake instead of a disk if the price was right.
I did buy a drum over a disk, I have no problems with a drum rear they work just fine and are not a problem to maintain. Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#15 | |
Jello Puddin'
I bought one with drums, cause it was over $200 cheaper than one with discs.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
