Fogged Windows - JeepForum.com
post #1 of 12 Old 02-20-2013, 11:56 PM Thread Starter
ShellyMoe
Fogged Windows
I have a 95 Wrangler soft top with no rear defrosters. Any suggestions on how to prevent fogging? Thanks!
-ShellyMoe
ShellyMoe is offline
post #2 of 12 Old 02-21-2013, 12:13 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The first step is to eliminate moisture on the inside of the jeep. Where's the leak? I think bestop has a spray for the vinyl windows to eliminate fogging. I know I use fog-x on my glass.
Luck Favours The Prepared
Anticanman is offline
post #3 of 12 Old 02-21-2013, 12:25 AM Thread Starter
ShellyMoe
Leak? Well, it's not sealed too tight. I'll try some anti fog stuff again. I did try the rain-x anti fog but that didnt work too well.
-ShellyMoe
post #4 of 12 Old 02-21-2013, 12:30 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Finding where the moisture is coming in is number one. Do you still have carpets? Are the drain plugs in? Have you considered slush mats? Is it more in the morning with condensation or in the afternoon when it heats up? Have you checked your vent hose on the firewall to see if its plugged?
post #5 of 12 Old 02-21-2013, 06:06 AM
nembudonna
Don't breath. Sorry.
nembudonna is offline
post #6 of 12 Old 02-21-2013, 07:10 AM
EABiker
You could run a small 12V fan positioned to blow air across the rear window; even an old PC CPU cooler fan should do the trick.
EABiker is offline
post #7 of 12 Old 02-21-2013, 07:15 AM
Rproject
1987 YJ Wrangler
Typically when my windows are fogged up, it's a good thing.
Sorry - couldn't resist.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 12 Old 02-22-2013, 02:19 PM Thread Starter
ShellyMoe
Lol Thanks! I'll try the fan, if that don't I'll try not to breath.its COLD here dangit!
-ShellyMoe
post #9 of 12 Old 02-22-2013, 02:21 PM Thread Starter
ShellyMoe
Drain holes are open 24/7 and I removed the carpet years ago. I get the fog mainly while its heating up and of course breathing doesn't help. I'll check the vent hose too.THANKS!!
-ShellyMoe
post #10 of 12 Old 02-22-2013, 04:44 PM
pete1991YJ
I just crank up the heater and let it warm up good and hot before I actually get in and go. OTOH my windows are so scratched up and milky that you can't hardly tell the difference anyhow - they're originals.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #11 of 12 Old 02-24-2013, 09:44 PM
JohnOllen
Make sure your vacuum lines to the HVAC are connected properly and also check to see if the air intake flaps (in the air intake on the hood) are responding the way they should in response to our HVAC controls. I had a real problem with my 92 fogging up when I'd use the heater. As soon as I corrected the vac line to the HVAC controller the fogging stopped immediately and the heat is fantastic.
JohnOllen is offline
post #12 of 12 Old 02-25-2013, 10:03 AM
90DesertTanYJ
As far as clearing oxidized fog, you can use Lemon Pledge. It works amazingly well in removing most of the UV generated fogging and makes yer YJ smell good too, lol.
90DesertTanYJ is offline
