Fog Light Wiring - JeepForum.com
post #1 of 4 Old 06-18-2001, 03:28 PM Thread Starter
Somohllik
Fog Light Wiring
Any one got any bright ideas on where i can install my fog lights without having the wire all exposed. I have a 1990 sof top jeep Wrangler YJ. I'd like to mount them up along the side near the door. I was thinking of attaching them to the windshield so it would not inrterfere with the top being pulled on and off, but i have no idea how i can run the wires without having them exposed. Is trhere some sort of secret or what? If you have any ideas PLEASE post. i am sure lots of people have similiar questions.
My 1990 YJ
Somohllik is offline
post #2 of 4 Old 06-18-2001, 09:51 PM
jpwranglr9
if you want to mount it on the window hindge, fold down the windsheld and put the wire across the inside of the top dash. you may also want a new seal at this time as well to prevent leaks. that would probably look the best. if you want to mount it higher,(figure out your own mount) and run the wires inside the black trim along the winsheld sides that the soft doors lay on. un bolt the 4 (i think) bolts and put it in there
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #3 of 4 Old 06-19-2001, 02:28 PM Thread Starter
Somohllik
Thanks for the tip. I just bought some mounts of www.quadratec.com that fit on the side of the windshield. I'll try to run the wires underneath like you suggested. Many thankx
My 1990 YJ
post #4 of 4 Old 06-21-2001, 02:31 PM Thread Starter
Somohllik
I got a follow-up question for ya. I got the mounts in place and the lights attached to the mounts. I folded down the windshield ran the wires underneath and onto the dash, now what?? How do i run the wires to the power source?? Do i have to drill through the frame or is there an easier way. I think i am stuck. The wires look nice and un-exposed, but now i just need a power supply. Any help is much appreciated.
My 1990 YJ
Some light wiring questions about a light bar Rescue13 JK Wrangler Technical Forum 2 01-28-2010 08:28 AM
fog light indicator light wiring questions. rocknjeep YJ Wrangler Technical Forum 4 12-27-2009 09:16 AM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 07:47 AM
Wiring a Light Bar Prerun TJ Wrangler Technical Forum 7 03-16-2007 08:45 PM
Fog Light Wiring RkyMtHigh TJ Wrangler Technical Forum 5 10-29-2003 08:02 PM
