fog light indicator light wiring questions. - JeepForum.com
post #1 of 5 Old 10-10-2009, 02:15 PM Thread Starter
rocknjeep
1987 YJ Wrangler
So last weekend I had made the mistake of leaving my fog lights on and draining the battery. Good excuse to finally by that optima yellow top which I did. While I was there I picked up a small indicator light to install on the dash.
I want to wire it up so that when I flip the missile switch to turn on the fog lights the indicator will come on as well. That way I don't forget to shut them off again. I've tried a few different things but can't seem to get it to work.
The closest I got was reversed. Fogs off indicator on/fogs on indicator off. I want it the other way around.
Has anyone done this or anything similar? Any help would be greatly appreciated.
rocknjeep is offline
post #2 of 5 Old 10-10-2009, 05:11 PM
jay-h
The indicator light should have 1 wire to ground and 1 wire to the load (light) side of the switch.
jay-h is online now
post #3 of 5 Old 10-10-2009, 05:16 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If you have 12V at the switch then one leg of the lamp goes to the 'power out' side of the switch the other leg of the dash light goes to goes to ground. When you power up the fogs that indicator light should also go on.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 5 Old 10-11-2009, 10:19 AM Thread Starter
rocknjeep
1987 YJ Wrangler
thanks guys. im gonna try this out and get back to you.
post #5 of 5 Old 12-27-2009, 10:16 AM
jbars
Wired mine through the ignition switch. That way they can't be left on without the key being on..Good luck
jbars
94 yj
hoosierland
jbars is offline
Some light wiring questions about a light bar Rescue13 JK Wrangler Technical Forum 2 01-28-2010 09:28 AM
Windsheild light mounting/wiring questions sbrendan420 TJ Wrangler Technical Forum 6 12-16-2009 10:51 PM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 08:47 AM
side marker light wiring questions... charlescho TJ Wrangler Technical Forum 2 08-12-2006 05:16 PM
KC light wiring questions Optik45 TJ Wrangler Technical Forum 5 08-18-2004 09:50 PM
