Foam seal below windshied. - JeepForum.com
post #1 of 12 Old 08-29-2013, 07:00 AM Thread Starter
Mikie
My foam seal has deteriorated badly. How much trouble is it to replace and where can you get a replacement?
Mikie is offline
post #2 of 12 Old 08-29-2013, 07:06 AM
superj
you can get it anywhere that sells jeep stuff. i particularly like morris 4x4 for stuff like that though.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 12 Old 08-29-2013, 07:07 AM
superj
http://www.jeepforum.com/forum/f12/w...stall-1568543/
superj is offline
post #4 of 12 Old 08-29-2013, 07:08 AM
Rproject
1987 YJ Wrangler
X2.
And to add, if you've never dropped your windshield, coat the pivot point of the hinge with some white lithium or teflon based lubricant a couple times before trying to swing it down. Also, if it's never been down, have one person on each side of the windshield as it may be tough to get it to start moving.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 12 Old 08-29-2013, 07:16 AM
jbrown73
Make sure you treat for any rust you might find once you fold the windshield down.
"The Constitution is not an instrument for the government to restrain the people, it is an instrument for the people to restrain the government....." - Patrick Henry
Originally Posted by Rproject View Post
The only thing I can say is to close your eyes. Seriously. If you close your eyes and pay attention to your finger tips, you'll be able to feel the nuts better and manipulate them easier.
jbrown73 is offline
post #6 of 12 Old 08-29-2013, 08:24 AM
GrantYJ
X2
If your gasket is bad, the top lip of your dash is most likely rusted badly. If you leave it like that, it'll only get worse and will potentially mess up your new gasket while you're trying to fold the windshield back into place.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #7 of 12 Old 08-29-2013, 09:59 AM
Mr.ThunderMakeR
What do you guys recommend for repairing the rust? Scrape away loose stuff and apply rustoleum?
- '91 Jeep Wrangler YJ, 4" lift with 33" BFG KM2's, 1" body lift, NV3550 swap, NP241OR Rubicon TCase w/ Novak Cable Shifter, Monstalined Tub
- '09 Mazda RX-8 R3
Mr.ThunderMakeR is offline
post #8 of 12 Old 08-29-2013, 10:06 AM
Rproject
1987 YJ Wrangler
Scrape, grind, POR-15.
1996 White ZJ
Rproject is offline
post #9 of 12 Old 08-29-2013, 01:47 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
That's the unofficial YJ motto.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #10 of 12 Old 08-29-2013, 02:07 PM
GrantYJ
"unofficial"....? I don't think so.
GrantYJ is offline
post #11 of 12 Old 08-29-2013, 06:07 PM
pasinbuy
Ditto, Rustoloem is a waste of time.
Whenever rust POR15....
pasinbuy is offline
post #12 of 12 Old 08-31-2013, 12:53 PM Thread Starter
Mikie
Thanks for all the help. Morris did have the seal.
Mikie is offline
