fml....the bell housing is stuck - Page 2 - JeepForum.com
post #16 of 20 Old 11-29-2011, 06:42 AM
boardmaker
I had to rock the crank shaft back and forth a little. Also, make sure the trans is in neutral.
boardmaker is offline
post #17 of 20 Old 11-29-2011, 04:16 PM Thread Starter
riverhippy
ok...got it out, i pulled it out because there was a loud know comming from the center of the bellhousing, i thought there would be a backed out bolt....but it looks pristine....again..fml
should i just rebuild it?
riverhippy is offline
post #18 of 20 Old 11-29-2011, 04:51 PM
bikerdude
1987 YJ Wrangler
Spin the throwout bearing by hand and see if it makes a noise something like you were hearing. Remember, it will be quieter spinning it by hand. Also remove the clutch disc and check it for broken or missing springs.
bikerdude is offline
post #19 of 20 Old 11-29-2011, 05:13 PM
bikerdude
1987 YJ Wrangler
I just ran across a thread of yours with video of a knock. If that is the reason for pulling the tranny, I am guessing you have an external slave cylinder for your clutch. If so you will see a shiny spot on the throwout bearing fork where it is contacting the pressure plate causing the noise. If I am right, replace the clutch disc (which will be totally worn out) and check the fork for a crack or a bend, replace the fork and your noise will be gone. (I hope I am right on this one)
Edit: If you have an internal slave please disregard this post!
post #20 of 20 Old 11-30-2011, 01:39 PM Thread Starter
riverhippy
its an internal slave cylinder, but thanks for your feedback
bell housing , girls , hot girl with tat , manual transmission
AX-15 Bell Housing Jeep_YJ YJ Wrangler Technical Forum 16 05-14-2015 08:03 PM
bell housing MisfitSeven TJ Wrangler Technical Forum 0 03-23-2010 09:13 PM
2.5L uprgrade to 4.0L - bell housing? turf-pro YJ Wrangler Technical Forum 9 03-12-2009 02:00 PM
bell housing ? NOTQUITEMUSASHI YJ Wrangler Technical Forum 2 01-09-2006 01:49 PM
AX-15 Bell Housing on a BA-10/5? boulderz YJ Wrangler Technical Forum 4 03-12-2005 08:31 AM
