fml....the bell housing is stuck - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > fml....the bell housing is stuck
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 11-28-2011, 07:15 PM   #1
riverhippy
91 YJ got all bolts loose on the bellhousing to my manual trans and pushed away from engine about an inch or so.....wont go any further. anything bad happen if i crank on it?
riverhippy is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 07:28 PM   #2
Axl Jack
I'm confused. Are you sure you're an inch away? At that point the tranny should be clear of the dowel pins.
Whenever I do it I take a pry lever and gently nudge it one side at a time. Wiggle it back and forth until it clears the splines and it SHOULD drop right out.
(Usually I have the opposite problem and can't get the splines to line back up! ha ha)
Did you support the oil pan with a block of wood on top of a jack? I don't know if it really matters, but I prefer to not have the entire weight of everything on the motor mounts. Like I said, don't know if it matters. Just my personal preference.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 07:28 PM   #3
ODGREEN4X4
Bell housing
Can't leave it there ! Sounds like all the bolts are out . Just pull it apart. Anything you break can be fixed later. The throw out bearing is binding up. or worse. Try not to bent the transmission shaft. Starter ,shifter and driveshafts are out ...Right ??
Ok GO ! Let me know how it goes !
ODGREEN4X4 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 07:45 PM   #4
riverhippy
yeah...everything is out and cleared dowl pins...i might be my trans jack w stuck wheels....i just wanted to b sure before i crank it...this is the first time i ever pulled a trans/clutch
Unread 11-28-2011, 08:29 PM   #5
ODGREEN4X4
yank it !
I have some spare parts if you need them !!LOL !
Unread 11-28-2011, 08:31 PM   #6
ODGREEN4X4
You can use some looong bolts for a guide (like studs) on it way out. Let us know whats hanging up ...
Unread 11-28-2011, 08:37 PM   #7
oldtime_ironman
Don't be afraid to put some real muscle into it. I've lost count of how many times I've pulled trannies.. count of 3, grunt and shove it around or yank... Just make sure everything is securely supported...
(Wait, that sounded really dirty, didn't it )
oldtime_ironman is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 08:40 PM   #8
Foundrydude
That's a flyweight transmission, forget the jack. Get under there and muscle it out by hand, put your knees under the bellhousing and grab the trans by the tail.
It's just the input shaft binding in the clutch and you're gonna have to work the transmission around while pulling on it.
Foundrydude is offline   Reply With Quote Quick reply to this message
Unread 11-28-2011, 09:12 PM   #9
oldtime_ironman
Keep yer knees together and your feet spread out when you do this. I forgot to once, and the trans dropped onto a certain part of my body. It greatly improved my singing voice.
Unread 11-29-2011, 01:17 AM   #10
riverhippy
wtf...are the flywheel n clutch supposed to stay attached to the engine????!!! the further i pull...the flywheel and clutch assembly stay attached to the engine
Unread 11-29-2011, 01:30 AM   #11
bikerdude
1987 YJ Wrangler
Yes, they stay with the engine. Once the tranny is out, you unbolt the pressure plate from the flywheel to get to the clutch disc. Then if you are removing the flywheel, unbolt it from the crankshaft.
bikerdude is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 01:40 AM   #12
moonshinefuel
You probably have to tilt the engine down further as the top of the bell housing is probably hitting the tunnel.
AX5/NV3550 Conversion Thread. http://www.jeepforum.com/forum/f12/n...irrels-752742/
Bow Hunting www.bowsite.com
moonshinefuel is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 03:11 AM   #13
wickedoffroad
1987 YJ Wrangler
Check to make sure you are not getting caught up on the exhaust. I cant count the times we have forgotten to remove it only to have it get in the way after about an inch or so from the engine...
wickedoffroad is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 06:23 AM   #14
1998zj
Did you take the shifter off of the top of the transmission?
"Our lady of blessed acceleration don't fail me now"
1998zj is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 06:27 AM   #15
Louie4
I say man up on it.
Oh and your thread tags are funny.
bell housing, girls, hot girl with tat, manual transmission
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
bell housing , girls , hot girl with tat , manual transmission
