Flywheel - trigger teeth vs. without - JeepForum.com
post #1 of 5 Old 04-26-2010, 05:51 PM Thread Starter
fran87yj
1987 YJ Wrangler
I just finished a tanny swap on my 87yj from the BA10/5 to the AX15. During the process I replaced my flywheel. Went to start the jeep and there is a loud grinding sound- metal on metal. Come to find out the flywheel I installed comes with or without tigger teeth for an 87. I had the flywheel without trigger teeth and installed the one with trigger teeth. The teeth are grinding on my starter.
What is the difference between the flywheels and is there a different starter I can buy to fit or do I need to take everything back off and replace the flywheel with the other one? They both come up for an 87yj, I am assuming there must be a starter that I can replace mine with.
Anyone know?
fran87yj is offline
post #2 of 5 Old 04-26-2010, 06:23 PM
Mark05059
I think what you got was a flywheel out of an injected (4.0) 6cyl. As such you should be able to get a starter out of a 4.0 cherokee
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 04-26-2010, 06:26 PM Thread Starter
fran87yj
1987 YJ Wrangler
thanks. I am sure I can replace my starter and solve my problem. I just need to figure out which one I need.
fran87yj is offline
post #4 of 5 Old 04-26-2010, 06:38 PM
Burnerman
Burnerman's Avatar
There were 2 starter options on the 4.2. You probably have the larger one with the firewall mounted solenoid. Get one for a 4.0L. The one in my 89 4.2 was exactly the same as the one in the 92 4.0. Much smaller diameter starter with the solenoid mounted on the starter
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 5 Old 05-04-2011, 10:10 PM
johnnykind
Wow exactly the opposite thing happened to me I had the flywheel with the trigger teeth and they sent me the one without, now I'm trying to find the right starter also...got the older style ford starter but it fits too tight the Bendix wont disengage from the flywheel...still trying to make it fit...let me know what happens with yours ...
johnnykind is offline
flywheel teeth 9inchsoflift YJ Wrangler Technical Forum 0 08-30-2009 07:16 PM
flywheel teeth 9inchsoflift YJ Wrangler Technical Forum 1 08-28-2009 06:22 PM
Would you pull the trigger on this LJ? JEEP-DADDY Wrangler General Discussion 9 06-04-2009 09:58 PM
how many teeth kbradner83 YJ Wrangler Technical Forum 0 10-09-2007 10:31 AM
Sae flywheel/flywheel housing sizes DieselWrangler TJ Wrangler Technical Forum 1 12-30-2005 03:31 PM
