flywheel/starter question... - JeepForum.com
post #1 of 6 Old 10-23-2006, 07:17 PM Thread Starter
BillR
BillR's Avatar
I'm in the process of swapping engines. My YJ is an '89, and the "new" engine is an '85. Both are from manual trannies.
I got the starter with the CJ engine, and it's a large starter with the "hump" on the side and only one terminal. The starter from the YJ is a two-piece unit with the bendix mounted on the outside and 3 wires total going to it.
The flywheel from the CJ engine is just under 1.5" wide, with the ring gear beginning about 1/2" from the seperator plate between the block and bellhousing. The flywheel from the YJ engine is under 1 1/4" wide, with the ring gear beginning on the inside edge of the 'wheel right next to the block/plate. The YJ 'wheel also has the slots cut for the CPS, even though mine's a carb unit.
1. Why the differences in the flywheels as far as size? Balance?
2. Can the YJ flywheel be swapped over to the CJ engine OR can the CJ starter somehow be made to work in the YJ?
TIA!
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #2 of 6 Old 10-23-2006, 07:24 PM
lah2420
I've got an 87 Wrangler with a 75 block in it. I used the 87 flywheel and starter.
lah2420 is offline
post #3 of 6 Old 10-23-2006, 08:01 PM
koeingsyj
Did you try fitting it. The starter will probably work. As for the flywheels I really have no idea. I know when I swapped my 87 for and 89 engine the flywheels and starter were different. Couldnt really figure that one out.
koeingsyj is offline
post #4 of 6 Old 10-23-2006, 08:09 PM Thread Starter
BillR
BillR's Avatar
The YJ starter won't work on the CJ flywheel. The throw of the bendix is shorter on the YJ starter, hence the reason for the different location of the ring gear.
BillR is offline
post #5 of 6 Old 10-24-2006, 06:32 AM Thread Starter
BillR
BillR's Avatar
This would be the easiest way as long as I'm not messing up the engine's balance...
BillR is offline
post #6 of 6 Old 05-04-2011, 10:02 PM
johnnykind
I know this is an old post but did anyone ever figure out if the cj style starter will work in the yj I rebuilt the motor and got a new flywheel but they sent me the early 87 more like the cj style with out the CPS ring...tried the old starter first obviously that didn't work so I tried the cj starter and it fits but its really tight the Bendix wont disengage from the flywheel. will a better starter from Napa work or do I just have to pull the tranny and put the old flywheel back on ??? really don't want to pull that tranny !!!
johnnykind is offline
New Starter New Flywheel....Help! jgowen YJ Wrangler Technical Forum 7 12-19-2010 04:56 PM
Starter / Flywheel Question kg6mti YJ Wrangler Technical Forum 3 09-08-2009 08:49 AM
starter flywheel? newjeeper369 YJ Wrangler Technical Forum 0 05-01-2009 12:27 PM
flywheel/starter question... BillR YJ Wrangler Technical Forum 0 10-25-2006 09:54 PM
Flywheel or starter???????? CanukYJ YJ Wrangler Technical Forum 7 09-30-2003 03:18 PM
