Flywheel question - JeepForum.com
post #1 of 18 Old 01-08-2013, 04:12 PM Thread Starter
epettit
Flywheel question
I am swapping the BA10 out next weekend with a AX15 and am going to buy a new flywheel in my 87 YJ instead of having the old one resurfaced. Looking at the pictures on different auto parts websites the flywheel for a 87YJ looks to have some funny looking teeth if you will next to the ring gear????
Is that the correct one for my year model?? I have not pulled mine part to see if the one installed looks the same way. I did not want to buy the wrong one!!!!
Thanks in advance
Ed Pettit
epettit is offline
post #2 of 18 Old 01-08-2013, 04:40 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Always good to ask. The picture posted below I borrowed from Richmond88YJ, it is posted up in his BA10/5 to AX15 swap thread in the FAQ, also worth reading, so it is linked below.
Your flywheel should look like this:
http://www.jeepforum.com/forum/f19/y...ite-up-312203/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 18 Old 01-08-2013, 05:41 PM
Que89YJ
The inner ring in the pic is a reluctor ring. It is for a crank position sensor and isnt needed for the carbed 4.2L. I know there is differences with the starters between the ba 10/ax 15. I am not sure but you can do a search for it.
This thread explains how to google the forum and get through the thousands of post:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
Que89YJ is offline
post #4 of 18 Old 01-08-2013, 06:28 PM Thread Starter
epettit
I did not think it would matter since the flywheel and ring gear will not change with the new flywheel since it will be the safer year as came out and the starter mounts from the front into the bell housing which I thought were interchangeable
Anyone????
Ed Pettit
epettit is offline
post #5 of 18 Old 01-08-2013, 06:59 PM
Que89YJ
Not sure. I seem to remember something about the Ford start but according to this thread you are ok:
http://www.jeepforum.com/forum/f12/b...4-2-a-1026286/
Que89YJ is offline
post #6 of 18 Old 01-08-2013, 08:44 PM
trboxman
1987 YJ Wrangler
I just did a BA10/5 to AX15 replacement this past July. That is not the flywheel that I have on my '87. That is a flywheel from an '88+. The reluctor ring notches, the square cutouts, are for a crank position sensor that wasn't used until later. The '87 doesn't have the reluctor ring notches. If you put that flywheel on an '87 you'll need to change your starter to match. The '87 starter will work just fine with an AX15 and the correct flywheel.
The '87 flywheel is the same as the '86 CJ flywheel.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #7 of 18 Old 01-08-2013, 09:29 PM Thread Starter
epettit
Thanks for the head up. I better take a peek at mine with a borescope before I purchase one. I am trying to get all the parts on hand before I swap it due to it a daily driver.
As is sits today with the BA10 when you start the engine the starter is very loud as in what I can only explain as screechy. The prev owner had just replaced the starter..... I wonder if he got the correct one.
Ed Pettit
epettit is offline
post #8 of 18 Old 01-08-2013, 09:41 PM
trboxman
1987 YJ Wrangler
It's very common for the part houses to not correctly list the '87 specific parts, in most cases it's a part that would be the same on an '86 CJ. I bought my replacement flywheel from Napa, they had the part correctly listed.
You can run the '88 flywheel and '88 starter with no issues, it's just that you can't mismatch '87 and '88 parts.
- Herbert Spencer
trboxman is offline
post #9 of 18 Old 01-08-2013, 09:55 PM
Que89YJ
That was it. I knew there was something different.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 18 Old 01-08-2013, 09:56 PM
Opihi59
Opihi59's Avatar
Yes, the one in my post above is from an 88, I didn't think they changed style until they switched over to the 4.0 but will try to look at part numbers online. The picture below for comparison is from my 93 4.0
So for O'Reilley's online, I'm gonna have to cry foul. They list the same number (NFW2006) for the 87 as well as the 88, but then they had the same part number and same photo for YJ 6 cylinder flywheels all the way up to 93 where I just quit looking. I know this isn't right, and yes, you're going to have to physically see your flywheel before you can really be sure of what to get from the parts store. Sorry I couldn't break the code on this one.
Opihi59 is offline
post #11 of 18 Old 01-08-2013, 10:00 PM
Que89YJ
I thought there was a change with going away from ford starters and the throw of it being different. I just remember reading it I never seen it myself.
Fault codes:
No Start:
Que89YJ is offline
post #12 of 18 Old 01-08-2013, 10:13 PM
trboxman
1987 YJ Wrangler
Yep, the early YJs had lots of transitional parts as they changed transmissions, transfer cases, starters, flywheels, v-belts to serpentine, etc. It can be a bit tough to nail down exactly what you need and how to make sure you get the right stuff from the parts houses.
- Herbert Spencer
trboxman is offline
post #13 of 18 Old 01-17-2013, 12:08 PM
1986cj
If your 87 is a Wrangler stock you have a 258. Only fuel injected 4.0 for the Cherokee (pre 91 was a renix ) and not in till 91 did the Wrangler get a 4.0. Your 258 share a lot of the same parts as a CJ.
1986cj is offline
post #14 of 18 Old 01-17-2013, 08:49 PM
Renegad87
1987 YJ Wrangler
I made this mistake when I rebuilt my engine. I bought a new flywheel 88-95 for my 87 and as people have said above a newer flywheel will work great with everything except the starter. You will need to purchase an 88-95 starter to match it. Not a big deal since the holes are the same. Only change is the wiring since the newer starter has a solenoid on it. Simple fix is to run a new wire from the old starter solenoid (mounted on the firewall) to the new one so the gear engages when the ignition is turned to start.
If you want I have pictures I can upload.
It's worth the switch since the gear reduction starter is so much smoother/quieter than the old ford model and draws less amps.
Renegad87 is offline
post #15 of 18 Old 01-17-2013, 08:52 PM
Opihi59
Opihi59's Avatar
Send the pictures.
Opihi59 is offline
