Flywheel inspection plate - JeepForum.com
post #1 of 14 Old 03-05-2012, 02:56 PM Thread Starter
jrayzhunter
Ok so I've searched the forums and found people who have the same problem I have which is "I was under my jeep fixing another problem" only to discover I can see my fly wheel. After a massive amount of searching I found the name was flywheel inspection plate or cover.
So now I looked to see where to find one. People said eBay, Craigslist, forums, etc. but I'm not having any luck. So I figured I would start this thread for people who might have found one help those find one who need it!
Let me know where you found it or if you fabricated it or what!
Thanks!
If it ain't broke..... blow it up!
jrayzhunter is offline
post #2 of 14 Old 03-05-2012, 06:00 PM
pasinbuy
Junk yard
pasinbuy is offline
post #3 of 14 Old 03-05-2012, 06:09 PM
castorriver
Do you have a pic of the opening?
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #4 of 14 Old 03-05-2012, 06:28 PM
SpikesHD
1987 YJ Wrangler
LOUD, isn't it! Mine's been missing since I had the engine rebuilt. Scares the heck out of bystanders!
Si vis pacem, para bellum.
SpikesHD is offline
post #5 of 14 Old 03-05-2012, 09:14 PM
dwtaylorpdx
The 2.5 cover on my 94 does not come off without dropping the tranny, covers the whole backside of the engine. without it your clearance between the input shaft and the pilot bearing also you clutch may be wacky....
Dave
dwtaylorpdx is offline
post #6 of 14 Old 03-06-2012, 06:50 AM Thread Starter
jrayzhunter
post #7 of 14 Old 03-06-2012, 06:52 AM Thread Starter
jrayzhunter
Originally Posted by pasinbuy View Post
Junk yard
I've had zero luck finding a wrangler in a junk yard. Tried to match up a Cherokee with it but no such luck. I'll just keep searching. Dont want to drive it until I get it back on so I don't screw up my clutch and whatever else that can get sucked up in there
post #8 of 14 Old 03-06-2012, 07:09 AM
bigbossd1030
What engine and tranny? External or internal slave. Ill do some looking around.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #9 of 14 Old 03-06-2012, 07:28 AM
Apollo12227
You can still drive the jeep regardless of the inspection plate. Mine has been missing for years and as long as your not going mudding and throwing mud everywhere you will be fine for road driving.
Apollo12227 is offline
post #10 of 14 Old 03-06-2012, 11:15 AM Thread Starter
jrayzhunter
That's all I bought it for was mudslinging!! I have a daily driver.
I found a website that makes factory chrysler parts. It's $53 with shipping but doesn't include bolts but I can pick them up at home depot or lowes. The bolts were way too expensive ordering through them.
www.factorychryslerparts.com (go figure huh it would be that easy?)
post #11 of 14 Old 03-07-2012, 09:45 AM
dwtaylorpdx
All 2.5 with manual trans should use the same piece... Its just really a flat piece of sheet metal with some holes punched in it... But if yours is like mine you'll have to drop the tranny to install it...
Dave
post #12 of 14 Old 03-07-2012, 07:46 PM Thread Starter
jrayzhunter
Dave
Not what I want to hear for just a thin piece of sheet metal. Hoping just to find the part. My chrysler website didn't have them.
post #13 of 14 Old 03-07-2012, 08:56 PM
Flajeeper1
1987 YJ Wrangler
Post here in the wanted section.
Flajeeper1 is offline
post #14 of 14 Old 03-09-2012, 09:36 PM Thread Starter
jrayzhunter
found the part on ebay finally... hopefully be installed whenever it gets here. It was listed under jeep inspection cover
Bell housing inspection plate angelo2975 TJ Wrangler Technical Forum 3 02-24-2012 12:36 PM
Where to find clutch inspection plate czjeeper YJ Wrangler Technical Forum 2 08-30-2011 03:10 PM
Inspection Plate Leak? cvisinho YJ Wrangler Technical Forum 6 06-23-2010 11:26 AM
Pulling inspection plate??? SignGuy321 YJ Wrangler Technical Forum 28 09-21-2009 05:44 PM
