flush mount lights - JeepForum.com
post #1 of 14 Old 08-30-2007, 06:54 PM Thread Starter
ponytail
flush mount lights
I have some 4" round LED's and I am not sure what size hole saw to use. Does anyone know what size I need to use? Thanks in advance Chris
SOLD! 93' YJ,CJ front clip, Now have a stock 96 XJ waiting to be lifted
ponytail is offline
post #2 of 14 Old 08-30-2007, 07:06 PM Thread Starter
ponytail
anybody? I need to know tonite doing the conversion tomorrow
ponytail is offline
post #3 of 14 Old 08-30-2007, 07:16 PM
timatoe
timatoe's Avatar
If they've got the grommet, then you need a 4 1/2 inch hole. I used a jigsaw for mine.
timatoe is offline
post #4 of 14 Old 08-30-2007, 07:17 PM
dgm5186
Give it some time man, you waited 12 minutes before posting again. Check it in the morning and I'm sure you will get a response.
Other than that I can't really say I have anything to add to your thread besides maybe checking the packaging of the led. They might have a table of sizes that would match the size of the light. Different manufacturers of lights = different size holes possibly.
~Dan
dgm5186 is offline
post #5 of 14 Old 08-30-2007, 07:43 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I used a jig saw also on mine. When you check the price of a 4 1/2" hole saw, you will too!
Mask off the body first so you don't scratch up the paint with the jig saw base plate. Make sure you don't cut too high or you will end up in the rear cargo area.
laybackman is offline
post #6 of 14 Old 08-30-2007, 08:40 PM
bryan-2kevo
ditto the jig saw
bryan-2kevo is offline
post #7 of 14 Old 08-30-2007, 08:52 PM
timatoe
timatoe's Avatar
Zactly............
timatoe is offline
post #8 of 14 Old 08-30-2007, 08:57 PM
maddydaddyyj
I made a templae out of thick construction papre and used a drem with a cut off wheel
4.0 ax15 np231 dana 30/35 33x12.50 on 15x10 cragars oba hand throttle soa on stockers
maddydaddyyj is offline
post #9 of 14 Old 12-01-2007, 08:55 PM
99dime
Did the jig saw tear up the sheet metal at all on the good side?
88 YJ 6cyl
95 "Family Style" Roll Bar
3.5" Tuff Country susp lift
2" BL
Dana 30,35
15x8 Ultra 164 wheels, 32x11.50 tires
99dime is offline
post #10 of 14 Old 12-01-2007, 09:06 PM
red87yj
red87yj's Avatar
1987 YJ Wrangler
if you want to use a jig saw, put down some painters tape and take your time. if you use a hole saw, look at the back of the box and it will tell you what size hole you will need.
Later
Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift
red87yj is offline
post #11 of 14 Old 12-01-2007, 10:11 PM
timatoe
timatoe's Avatar
No, didn't hurt it. As mentioned use some tape around the area you're cutting. I would've used a RotoZip tool thing if I had one.
timatoe is offline
post #12 of 14 Old 12-02-2007, 11:33 AM
goatboy
I feel your pain...had the same question when I mounted my flush LEDs...had to actually measure my rubber gasket... what a mind bending experience... I agonized for weeks!! LOL
goatboy is offline
post #13 of 14 Old 12-02-2007, 05:14 PM
99dime
I have one of those drill bit cutters for my dremmel im just not sure how that would work on sheet metal.
88 YJ 6cyl
2" BL
Dana 30,35
99dime is offline
post #14 of 14 Old 12-02-2007, 07:16 PM
Douglas S.
a hole saw is what i used- if you've already got one it's the best route- not worth buying though
1991 Land Cruiser HDJ81
Douglas S. is offline
Flush mount LED tail lights RedWind YJ Wrangler Technical Forum 16 02-06-2010 07:26 PM
flush mount tail lights? thetrashman YJ Wrangler Technical Forum 38 01-23-2010 05:43 AM
Flush Mount Tail Lights tjSport06 TJ Wrangler Technical Forum 3 07-25-2008 03:45 PM
LED flush mount lights robertrw TJ Wrangler Technical Forum 4 07-20-2007 09:36 PM
flush mount driving lights TAMUJeep TJ Wrangler Technical Forum 4 05-28-2005 11:16 AM
