Flush mount LED's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Flush mount LED's
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-26-2008, 11:18 PM   #1
ReyesYJ
Flush mount LED's
Ok, need some help. Just installed brand new flush mount LED tail lights today. All wiring is correct, at least I'm 99.9% positive it is. Everything works great, running lights work as they should, brake lights work as they should and when the hazards are engaged, they blink as they should..........but of course, there always has to be one problem. When the turn signals are engaged, it is just a constant light, no flash. Not too sure why the hazards blink as they should but the turn signals don't. Any input would be greatly appreciated. Thanks.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)==@=)_)
ReyesYJ is offline   Reply With Quote Quick reply to this message
Unread 12-26-2008, 11:22 PM   #2
95greenrio
Sounds like you need to get a new signal blinker thing. Its the bell shaped black thing on the bottom of you fuse panel, you need one that will work with the lower resistance leds.
1995 YJ Rio Grand - work in progress
95greenrio is offline   Reply With Quote Quick reply to this message
Unread 12-26-2008, 11:24 PM   #3
Kenbo-Slice
Many times the blinker relay needs to be swapped when LED tail lights are installed. I'm not sure if this could be your problem, but it would be a good thing to check out, and they are pretty cheap. Hope you get it worked out, and post pics when your done!
Kenbo-Slice is offline   Reply With Quote Quick reply to this message
Unread 12-26-2008, 11:26 PM   #4
UltimatE
Resident Audio Guru
UltimatE's Avatar
You need to replace your turn signal flasher with an electronic based flasher. NAPA carries the part.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote Quick reply to this message
Unread 12-26-2008, 11:53 PM   #5
Brads_nky_yj
go into napa, advanced auto, autozone, pep boys...find the correct LED flasher so your jeep. I believe the flasher you want to get is the EL-12. Its only a few bucks, then look up under your dash, like above where your feet are when you drive and find the fuse panel and you will see the old fuse. Pop it out and put in the new and you are good to go!!
93 YJ - SOLD
Brads_nky_yj is offline   Reply With Quote Quick reply to this message
Unread 12-27-2008, 09:40 AM   #6
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, it is an EL-12 flasher module that you need. I just bought mine last week at NAPA for $11.99 and they usually have them in stock.
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote Quick reply to this message
Unread 12-27-2008, 12:21 PM   #7
ReyesYJ
Onjce again, Jeep forum to the rescue. Thanks a bunch. Will post pics when Im done.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)==@=)_)
Unread 01-09-2009, 08:25 AM   #8
ReyesYJ
Finished
Here they are installed. Came out pretty good. Bright as hell!!:thumbsup
http://www.jeepforum.com/gallery/data/4/Gallery42.JPG
/l , [____],
l---L--[]lllllll[]-
()_) ()_)==@=)_)
Unread 01-09-2009, 08:42 AM   #9
AthruC
Clicky-free
AthruC is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 09:24 AM   #10
JaikYJ
Wow that is a really nice looking jeep I love the tan top on the blue body. Very sharp!
Now you just need to make a plate that covers the BL on the back!!
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 09:37 AM   #11
UltimatE
Resident Audio Guru
UltimatE's Avatar
Are those clear tails ?
-Matt
White '94 YJ Sport
Unread 01-09-2009, 10:29 AM   #12
timatoe
Don't know how strictly it's enforced out there in NJ, but you may want to put some red reflective tape or something on the rear. Red reflectors to the rear are required in all 50 states, that's like a $380 ticket here.
Looks good though.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 01-10-2009, 12:12 PM   #13
ReyesYJ
Yea, my rear bumper is almost done being fabricated. There will be a diamond plate cover to cover that BL. Can't wait for that.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)==@=)_)
Unread 01-10-2009, 12:12 PM   #14
ReyesYJ
The lens are clear. The diods light up red when on. Oh an dhow did you ad the pic directly into the post so you don't have to click the url. Was trying to figure it out forever.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)==@=)_)
Unread 01-10-2009, 02:16 PM   #15
BlackRhino
You need 50 tech posts and 30 days of membership to be able to have your pictures show up. Or be a paying member.
Edit: It may not be 50 posts anymore, I'm not sure.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline   Reply With Quote Quick reply to this message
