Flush Mount LED's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Flush Mount LED's
Unread 08-27-2003, 11:31 PM   #1
TellyDSP
Poland and PPV!!!!
Flush Mount LED's
I'm liking the flush mount taillights, but I'm a little unsure about the wiring. Every LED light I've found replaces the running/blinker/stop light. What about the back-up's? I looked at the wiring diagram(below) and only concluded that the "75" wire would have to be run to a seperate lamp from the "79" and "72" wires which run to the red LED's. How wrong am I and how is it done? Also, does anyone make white LED's(lights, not bulbs)?
Thanx
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote Quick reply to this message
Unread 08-28-2003, 12:16 PM   #2
bigsteve3184
You got to have a seperate light for reverse...I just used a cheap tractor light and hooked up to a toggle switch...
It works great...BUT....that will not pass inspection. First off...thats a Off road light only. Second It has to be hooked up to your reverse wires. You can get some "back up lamps" from pep boys or autozone. Just hook those up to "75"
95 YJ 2.5L
SOA/2" BDS Springs/ 1" body
D44 ARB/Ford 9" Detroit Locker/5.13/ 36's
www.novajeepers.com
bigsteve3184 is offline   Reply With Quote Quick reply to this message
