Flush Mount LED's - JeepForum.com
post #1 of 2 Old 08-27-2003, 10:31 PM Thread Starter
TellyDSP
Poland and PPV!!!!
Flush Mount LED's
I'm liking the flush mount taillights, but I'm a little unsure about the wiring. Every LED light I've found replaces the running/blinker/stop light. What about the back-up's? I looked at the wiring diagram(below) and only concluded that the "75" wire would have to be run to a seperate lamp from the "79" and "72" wires which run to the red LED's. How wrong am I and how is it done? Also, does anyone make white LED's(lights, not bulbs)?
Thanx
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #2 of 2 Old 08-28-2003, 11:16 AM
bigsteve3184
bigsteve3184's Avatar
You got to have a seperate light for reverse...I just used a cheap tractor light and hooked up to a toggle switch...
It works great...BUT....that will not pass inspection. First off...thats a Off road light only. Second It has to be hooked up to your reverse wires. You can get some "back up lamps" from pep boys or autozone. Just hook those up to "75"
95 YJ 2.5L
SOA/2" BDS Springs/ 1" body
D44 ARB/Ford 9" Detroit Locker/5.13/ 36's
www.novajeepers.com
bigsteve3184 is offline
flush mount taillights johnroot01 YJ Wrangler Technical Forum 0 09-14-2009 06:50 AM
Flush mount LED's ReyesYJ YJ Wrangler Technical Forum 18 01-13-2009 11:12 AM
Flush mount taillights jdietz92 YJ Wrangler Technical Forum 6 09-24-2008 04:31 PM
ORO led's...Use with cb antenna mount??? conifers4 TJ Wrangler Technical Forum 2 07-08-2008 04:24 PM
Is it possible to flush mount... BunnyHunter TJ Wrangler Technical Forum 7 07-20-2004 02:20 PM
