Fluid leak from where bellhousing meets tranny - help - - JeepForum.com
post #1 of 3 Old 05-13-2013, 09:36 PM Thread Starter
killakeane
1987 YJ Wrangler
Okay, so I had been having a problem with a soft clutch for the past month or so.. so I went ahead and put in a new m/c and that seemed to do the trick but now she's back too her old ways of having a soft/spongey or completely dead clutch.. i put some fluid in the m/c and the jeep was sitting outside for a few hours i went to drive somewhere and the clutch was dead.. tons of fluid, i guess its the dot 3 since the mc was empty.. could it be the slave that's going? im not sure.. there was a bolt on the drivers side missing so i put a new one there about and hour ago but it was still dripping, I'll check it in the morning.. any input?
also first gear almost never goes in unless i pump it a sh*t ton or i turn the engine off, slide it in and start her up again, and reverse grinds - synchro prob?
killakeane is offline
post #2 of 3 Old 05-13-2013, 09:46 PM
Mark05059
you have just diagnosed your problem correctly. your slave is toast.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 05-13-2013, 10:01 PM Thread Starter
killakeane
1987 YJ Wrangler
thanks for the quick reply... that's what i figured but have no experience with them so ill have to find some good right ups on it.
bellhousing , help needed , leaking fluid , synchronizers , tranny problem
