Fluid leak at bell housing, what up ? - JeepForum.com
post #1 of 4 Old 10-27-2013, 02:56 PM Thread Starter
azjeepbud
hey buds, 89 yj here, been noticing small fluid leak at bell housing. Shes been drippin for awhile.....jumped into her this am and noticed clutch pedal has half the play than last eve, fiqured it's hydrolic fluid associated with clutch system. where do I start ?.....and what should be replaced.
thanks jeff
azjeepbud is offline
post #2 of 4 Old 10-27-2013, 03:54 PM
Mark05059
slave cyl.. depending on the milage and what parts look like when you get in there... complete clutch set up...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 4 Old 10-27-2013, 10:15 PM
baktie_91YJ
I have the same problem, but i think mine is the input shaft seal. You could check that when you tear it down
baktie_91YJ is offline
post #4 of 4 Old 10-27-2013, 11:22 PM
befumo
Any of the above plus possibly the rear main seal.
If you are replacing the hydraulic clutch replace the master and slave as a pair.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
