Fluid Capacitys for 95 YJ - JeepForum.com
post #1 of 4 Old 09-16-2006, 11:47 AM Thread Starter
plasmacastor
Is there somewhere on this site that you guys have this(more specifically...the trans, transfer case and diffs), and how am I supposed to find out what type of standard trans in it?
lastly, I would like to run synthetics in all of them, not sure which type in the trans, it seems some take "manual trans" and some take "GL-5".....was thinking of going the royal purple route....
plasmacastor is offline
post #2 of 4 Old 09-16-2006, 12:16 PM
arbby
2005 KJ Liberty
Could try the FAQ up top.
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #3 of 4 Old 09-16-2006, 12:52 PM
Wrangler95CSA
Wrangler95CSA's Avatar
Plasma, I've got a 95 YJ just like you, so I'll go ahead and give you the specs to save the headache of trying to find out for yourself. Just FYI, these fluid capacities came directly for the 1995 Jeep Factory Service Manual.
2.5L I4 Engine
Engine Oil: 4 quarts, 10w30
Aisin AX-5 transmission: 3.2L (3.3 quarts), 75w90 GL-5
30RH Auto transmission: 8.2L (17.5 pints), ATF+
Anti-freeze/Coolant: 8.5L (9 quarts)
4.0L I6 Engine
Engine Oil: 6 quarts, 10w30
Aisin AX-15 transmission: 3.15L (3.32 quarts), 75w90 GL-5
32RH Auto transmission: 8.2L (17.5 pints), ATF+
Anti-freeze/Coolant: 9.9L (10.5 quarts)
NP231 transfer case w/MANUAL transmission: 1.5L (3.25 pints), Dexron II ATF
NP231 transfer case w/AUTO transmission: 1.0L (2.2 pints), Dexron II ATF
Dana 30 front axle: 1.65L (3.76 pints), 80w90
Dana 35 rear axle: 1.6L (3.38 pints), 80w90
Personally, I go with Mobil 1 fully synthetic fluids in my entire rig. It's more expensive, yeah, but they're more than worth what you'll pay in the long run. I've never used Royal Purple, so I have no first-hand experience with them, but the people that I've talked to that have used them, love them. Hope this helps.
1995 Emerald Green Wrangler YJ 2.5L, AX-5, NP231 SYE, 33" x 12.50" X-terrains, 6" ProComp CSC, 4.88's F&R, K&N Intake, Banks Power Exhaust Manifold & Cat Back, MagnaFlow Cat, AirAid Throttle Body Spacer, Rock-It 60MM Throttle Body, Mean Green Alternator, Reverse Glow Halo Gauges, JKS Quick-Disconnects, Energy Suspension Body Mounts, Warn Rock Crawler Bumpers F&R, Warn Spare Tire Carrier, Warn 9.5ti, Brown Dog Motor Mounts, Flow-Kooler Water Pump
My RigRater Score: 501RRv1.0 with a BOA of 21.30
Wrangler95CSA is offline
post #4 of 4 Old 09-16-2006, 10:18 PM Thread Starter
plasmacastor
Thanks alot wrangler.......yes it did, i think mine is the same color as yours too
1989 4.2 transmission fluid leak, noob needs help checking fluid level. Sushorty22 YJ Wrangler Technical Forum 3 08-17-2012 12:09 PM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 08:11 PM
What do you guys use to change the tranny fluid and xfer case fluid?? Wheelman TJ Wrangler Technical Forum 11 12-15-2004 04:33 PM
Differential fluid / Transfer case fluid varsityboyz TJ Wrangler Technical Forum 4 09-07-2004 05:45 PM
Transmission Fluid, Diff Fluid, and Transfer Case markdonnell1975 TJ Wrangler Technical Forum 3 05-27-2004 02:27 PM
