fluid capacities - JeepForum.com
post #1 of 2 Old 05-08-2006, 02:41 PM Thread Starter
wraithyjeep
wraithyjeep's Avatar
fluid capacities
I need to change all my fluids before she goes on the road.
can some one inform me of the correct amounts of fuid my jeep requires.
oil 10 w 30=== 6 litres
coolant done
power steering done.
transfer case dex III ===????
front diff===?????
rear diff===?????
5 speed all i can find up here in Canada is synthetic GL-5 approved other wise I stuck using dino GL-5 weight===???
Silver Rubi JK unlimited.
89 YJ, 4.2, 5 speed, 2" lift, 235 75 r 15 M/T. CRT's HEI, MC2150 1.08, OBA, 120V inverter. removable Light bar, 10 hella lamps, trail rack w/ jerry cans, champion winch, high lift jack, C.B., lined tub. H4 Conversion headlamps, reveiw mirror w map lights. royal blue with matching trailer.
wraithyjeep is offline
post #2 of 2 Old 05-08-2006, 04:05 PM
Bob_R
4.0 I assume 4.2 would be the same:
engine oil 6 qt. 5.7 liters
cooling system 12 qt. 11.4 liters
AX-15 - 6.75 pints 3.15 liters GL5 75w-90
Front/Rear Axle 2.5 qt. 1.2 liters limited slip add Friction Modifier
Transfer case 3.3 pints 1.5 liters ATF Plus, Mercon or Dexron II
Now I use sys in my transmission (better shifting) and syn in my transfer case (longer life). Red Line is a good product but I use Mobil 1, with Royal purple in the transfer case.
If you use it always in Canada you might check into going lighter weight on oil.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
TJ fluid capacities wyldejackyl TJ Wrangler Technical Forum 5 11-07-2012 10:56 AM
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 1 01-11-2008 04:51 PM
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 0 05-02-2007 08:07 PM
fluid capacities bfr TJ Wrangler Technical Forum 7 12-14-2006 12:44 PM
87 YJ fluid capacities Buzzard YJ Wrangler Technical Forum 3 12-09-2001 09:50 AM
