Flowmaster - JeepForum.com
post #1 of 17 Old 07-10-2004, 11:37 AM Thread Starter
483Fitter
483Fitter's Avatar
Flowmaster
Its time to get a new muffler, to many rocks hit mine. I was thinking of putting on a flowmaster but wasnt sure how it would sound, anyone have any expierence with one on a jeep?
483Fitter is offline
post #2 of 17 Old 07-10-2004, 03:43 PM
Silver yj
Depends on what motor you have but I installed a flow on a 4 cylinder with single in dual out and ran the tail pipes in fromt of the tires and it sounds better then most,deep idel and stays like that till around 3500 rpm's then starts to get a little loud.
Silver yj is offline
post #3 of 17 Old 07-10-2004, 06:45 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Don't forget about the cherry bomb convertor
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #4 of 17 Old 07-10-2004, 08:13 PM
Hokie_YJ
The RockFather
Hokie_YJ's Avatar
how much did that setup cost ya. i'm kinda interested in doing something similar when the dolla bills ain't so tight. is there any noticable difference performance-wise, or just mainly in sound?
"Beat it like it owes you money"
Jeep Wrangler with some bolt-on "stuff"
Hokie_YJ is offline
post #5 of 17 Old 07-10-2004, 08:20 PM
Silver yj
You need a 3 inch body lift so you can run the tail over the frame and out in front of the wheels,price depends on what route you want to go,its hard to run the exhaust this way with the factory cat,you can get a high flow,cut it off,or have the factory moved closer to the engine for the room to run the pipes this way.A high flow cat is 89.95,flowmaster is 79.95 and the tail pipes will very with each shop sence it has to be cutome bent pipes.Had about 275.00 in the setup.Some HP gain but more noise then anything.
post #6 of 17 Old 07-11-2004, 10:35 AM Thread Starter
483Fitter
483Fitter's Avatar
im not looking to do anything trick, just cut out the stock one and put the flowmaster in its place, oh and its the 4.0 L engine
post #7 of 17 Old 07-11-2004, 12:27 PM
kcdee00
Awesome
I have a 40 series delta flowon my 4.0, and I think it sounds awesome...a lot of people ask me if I have a V8 under the hood!!! I dont have a catalytic converter, but I don't think that would change the sound.....I had a 50 series delta on my Rubicon, but I wanted something a little louder for this beast. It isn't tooo loud though, I think its just right....go for it
95YJ, d44 front, 8.8 rear (aussie locker), 5.13's, SOA, 36" Iroks
kcdee00 is offline
post #8 of 17 Old 07-11-2004, 03:34 PM
fl_frank
i put on a flowmaster super delta 50, and it's nice. not too loud (especially inside), and sounds decent outside (my wife thought i had a hole in my muffler, if that gives you any indication). don't think it's quite as loud as the regular delta 50, but with my soft top, it's just right. bought it off e-bay for about $70.
fl_frank is offline
post #9 of 17 Old 07-11-2004, 03:46 PM
PaxtonTransAm
PaxtonTransAm's Avatar
It will sound great. I have the 2 chamber, not the 3 that they will tell you to get. V-Force is a good spin off though for even less money.
98 Jeep Wrangler 4.0 Sahara, auto, alpine, JL audio speakers, 3chamber flowmaster,pace setter air intake, accell coil, a few other things
PaxtonTransAm is offline
post #10 of 17 Old 07-11-2004, 10:18 PM
newbee
newbee's Avatar
I always hear bout guys going with flow masters in my area (lots and LOTS of Z-71's) Some get new headers and stuff. If i wanted to run 40 series on my stock yj, would i need new headers? About how much do they cost also?
93 Wrangler, I6, Electric Blue, no lift yet....
Overhead K.C lights
In Progress With
4" rubicon express lift
33x12.50
SYE
15x10" rims
newbee is offline
post #11 of 17 Old 07-11-2004, 11:12 PM
yjnick
yjnick's Avatar
no you would not need new headers. I just got a 40 series on my 4banger and it sounds pretty good. I was going to put a new set of heads on ther ebut decided it would probably be a waist.
yjnick is offline
post #12 of 17 Old 07-12-2004, 07:53 AM
PaxtonTransAm
If he is in the exhaust changing mood he might as well before his stock manifold cracks like they all do around 60-70k miles (well most of them, all that Ive seen or heard of)
Did you do a v8 swap, im only asking because you dont have any info in your sig and you said "heads" leaving me to wonder where the other one would go?
post #13 of 17 Old 07-12-2004, 08:50 AM
JayJEEPguy
JayJEEPguy's Avatar
hhahaha whoops. wrong thread.
JayJEEPguy is offline
post #14 of 17 Old 07-12-2004, 11:04 AM
yjnick
yjnick's Avatar
i wish i had a v8 I have a 2.5. I dont know how to put anythig in my sig. i looked last night for it but couldnt find out how to.
I have 108,000 on my rig and still stock header
yjnick is offline
post #15 of 17 Old 07-12-2004, 11:28 AM
yjnick
yjnick's Avatar
nm about the sig i just found it
92 yj 4 banger 3.5" with 32's black rock crawler rims flowmaster 40 series funnel ram intake system
yjnick is offline
Flowmaster!! twinjeep97 TJ Wrangler Technical Forum 6 02-20-2008 11:27 AM
Which flowmaster? samger2 TJ Wrangler Technical Forum 7 02-12-2007 10:15 AM
Flowmaster 40 on 2.5? Black Hills TJ TJ Wrangler Technical Forum 2 02-11-2007 10:17 AM
Got my new Flowmaster 40 on! dummerdrummer TJ Wrangler Technical Forum 4 03-03-2006 07:12 PM
flowmaster 40 for the TJ.... charlescho TJ Wrangler Technical Forum 2 02-09-2006 08:14 PM
