floor plugs - JeepForum.com
post #1 of 11 Old 03-26-2007, 02:36 PM Thread Starter
Fuzz21
Fuzz21's Avatar
floor plugs
Does anyone know where to get those 3-4" body plugs that are in the floor on the drivers and passengers side? They are not the usual 1' plugs
1985 CJ-7, 258 w/a weber carb and HEI, 2.5"lift w/32" tires, 1/2"shackle lift, Dana 300, T-5, AMC 20 w/one piece axels, and Dana 30, YJ tub swap w/CJ tailgate, chevy blower motor upgrade, homeade body sliders, flush mount LED taillights......much more to come!!
"And on the eigth day, Man created BEER!"
Fuzz21 is offline
post #2 of 11 Old 03-26-2007, 02:44 PM
Angelous
1987 YJ Wrangler
never seen one so big. Mine were 1"
"There is no hole to deep, or mountain to steep, for the driver of this Jeep!"
87 YJ - 2.5 - TJ Flare Swap - Rubicon's - no track bars -
Angelous is offline
post #3 of 11 Old 03-26-2007, 03:30 PM Thread Starter
Fuzz21
Fuzz21's Avatar
It's a metal plug that is right in the middle of the floor, I have never seen one either but since it's a yj tub i figured you guys would maybe know
Fuzz21 is offline
post #4 of 11 Old 03-26-2007, 04:21 PM
timatoe
timatoe's Avatar
I had never seen them that big either, but someone posted pics of their "new" YJ the other day with bunch of rust and there was a plug like that in the pic big 3-4 incher. Sorry don't know where to get those. The standard small ones can be had on eBay for around $5 though.
timatoe is offline
post #5 of 11 Old 03-26-2007, 04:52 PM
jonnyri
jonnyri's Avatar
I know what you're talking about - dead center in the middle of the front floorboard... took mine out when I herc'd it... haven't found them since. Tried online - no luck. Maybe a dealer part - try to find it for a '95.
I just got cheap heavy rubber floor mats - worked well all winter.
Dirty, rusty, banged up YJ.
OSJ / NEA Delegate
jonnyri is offline
post #6 of 11 Old 03-26-2007, 04:56 PM
EJames1226
EJames1226's Avatar
None of my friends in 93 or earlier jeeps have them, i was wondering if it was a drain plug, its in the perfect spot for one, all the water would drain out right there.
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #7 of 11 Old 03-26-2007, 05:01 PM Thread Starter
Fuzz21
Fuzz21's Avatar
The tub is a 1995 and I have looked online as well w/o any luck, the one i have is o.k. but it's pretty rusty so i figured while the tub was off i'd just replace it, I'll check w/the dealer tomorrow and if no luck then i'll just sandblast it and put a thick coat of herc on it.
Fuzz21 is offline
post #8 of 11 Old 03-26-2007, 07:30 PM
Kush69
I've never seen any that big. I just welded all the drain holes in my floors, went to the parts store and bought 2- 2" expansion plugs and drilled new holes, one in the middle on each side now if I get water in I just pull the plug, and it quiter in the cab with no holes for road noise.
Kush69 is offline
post #9 of 11 Old 03-28-2007, 10:01 AM
Cannon
Cannon's Avatar
Whoa! floor pan plugs, whether in the front or behind the driver & passenger seats are an easy find!
LOWES for 0.79 a pair!
Go down the hardware isle (screws & stuff or nuts & bolts), and they've specialty drawers with a pic of em on front. On my '90 there's two sizes-but since so cheap, buy a handfull of both. I've Herc'd over them, or pulled them out for those weekly summer hose out the interior for easy cleaning jobs. Then usually have to buy again for the winter temps. Man I bet you guys buy them all up now.
'90YJ Hard & Soft w/Full Drs; 4.2 Rebuild w/ Webber, 30x10.5; Interstate MegatronII D34; Mods: Rock Guards; Hi Lift Inst; Herc'd Tub, Front & Under; Elev Rear Seat; Scty CntrConsole/ Overhead&Rear Boxes; KC Lights-Fr & Rear; PA Sys; Gauges; Int Lts; Batt/Alt Cable; Heater Mods; 8K Winch, KargoMaster Rack w/Yak Megawarrior Basket; Ground Lights (4);Dumped - Optima Yellow after only 4yrs
Cannon is offline
post #10 of 11 Old 03-28-2007, 10:09 AM
jdarg
I know what you are talking about, my 94 has them too.
My plan is to weld a round plates to each hole, paint, and forget about them. If you aren't a welder, epoxy would probably work just fine too.
-jd
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #11 of 11 Old 03-28-2007, 10:40 AM Thread Starter
Fuzz21
Fuzz21's Avatar
OK thanks I just picked up some metal so it think thats what i'm going to do. I plan on putting in different plugs for drainage anyway and then using herc on the tub.
Fuzz21 is offline
02-TJ Tub Floor Plugs archimeech TJ Wrangler Technical Forum 13 10-11-2008 06:06 PM
Floor Plugs ss454 YJ Wrangler Technical Forum 16 09-26-2008 02:09 PM
floor plugs 95YJRookie YJ Wrangler Technical Forum 7 07-27-2006 09:40 PM
floor plugs jbars YJ Wrangler Technical Forum 13 08-19-2005 12:00 PM
FLoor Pan Plugs? Nate1975 TJ Wrangler Technical Forum 5 11-05-2003 07:19 PM
