Flooding issues - JeepForum.com
post #1 of 6 Old 10-05-2013, 11:14 PM Thread Starter
mangomankw
Flooding issues
I have 1990 wrangler 2.5cyl. and it is flooding out when I try to start it. I know very little about engines however my friend is a certified mechanic that works on Jeeps a lot and we are both stumped. So here is what is going on. The Jeep started giving me trouble when I tried to start it. You could smell gas without even hitting the gas. When driving and changing gears it would try to shut off on me like it was flooded. We have changed the following parts: The computer, the dist cap and rotor, plugs, the position sensor, Map sensor, new fuel injector, we rebuilt the part that pushes on the butterfly (sorry don't know the name), fuel filter, new fuel pressure reg ( the new spring would not fit in the old space so we used the old spring and new diaphragm, new coil, and the part the coil plugs into ( again don't know the name), checked the relay. The 2 plugs closest to the dash would be wet with gas, and the compression was at 120 in all 4 cylinders. Maybe some things I forgot. At this point the injector is spraying less fuel but drips fuel in the throttle body to the point that there is fuel puddling in the bottom. When you turn it over there is the initial spray of fuel then a dribble of fuel until you take out the key or relay. Ok there you have it feel free to ask any questions and if I can't answer I will ask my friend Thanks
mangomankw is offline
post #2 of 6 Old 10-07-2013, 07:49 AM
Que89YJ
Your injector is bad. It says its new but if anything is coming out of the injector before it starts your injector is bad. You also need to read the fuel pressure. it should be at 15 psi. The pressure test will tell you a bunch of things. Go through this thread:
http://www.jeepforum.com/forum/f12/t...start-1496037/
Use the links to get to Shaefs threads.
Que89YJ is offline
post #3 of 6 Old 10-07-2013, 01:16 PM Thread Starter
mangomankw
Thanks Que very much having another sent to me
post #4 of 6 Old 10-07-2013, 01:44 PM
Que89YJ
Do the fuel pressure test both before and after. There are other issues that might be going on. You replaced the regulator then you need to adjust the pressure.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 6 Old 10-20-2013, 09:48 PM Thread Starter
mangomankw
Ok got new injector in will check fuel pressure. It starts when cold but rough and runs good once going however when it reaches temp it dies on me. Was told it could be the head does that make any sense?
post #6 of 6 Old 10-21-2013, 03:55 AM
Que89YJ
Fuel pressure test. Like I said there might be something else going on. The fuel pressure test will show it.
Fault codes:
No Start:
Que89YJ is offline
