Float Bowl Vent Hose identification- Weber install - JeepForum.com
post #1 of 8 Old 06-18-2013, 09:53 AM Thread Starter
Wranglin88yJ42
So I know there are 100 posts on the Weber upgrade, but I cannot find anything that helps me to identify the FLOAT BOWL VENT HOSE.
I'm putting the Weber K551-38 into a 1988 Sahara 4.2.
Can someone please take a look at the picture of my Carter at the below link and tell me which is the FLOAT BOWL VENT HOSE? If you can identify the other labeled hoses, that would also be a great help. Many thanks!
http://s1329.photobucket.com/user/Wr...f0527.jpg.html
Wranglin88yJ42 is offline
post #2 of 8 Old 06-18-2013, 10:14 AM
superj
can't open link at work.
i didn;t think weber had vents hoses for the bowl
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 8 Old 06-18-2013, 11:26 AM Thread Starter
Wranglin88yJ42
The Weber 38 has a float bowl vent hose fitting to the left of the fuel supply inlet (sort of points at the grill of the jeep). Unless there is something unique to 1988 4.2L's, the Weber 38 has the fitting for the float bowl vent hose and specifies to connect it in the "installation guide."
Not sure why the link won't work, it just goes right to photobucket when I click.
Thanks for any and all feedback, new to the Jeep community and could use a little help on this one.
post #4 of 8 Old 06-18-2013, 02:41 PM
superj
My work blocks photobucket. I can look now
What is that carb off of? Numbe 4 is the solenoid that bumps your idle up when you turn the ac on. That tiny little hose at number 3 looks like it goes to the cruise control or to something like that, maybe the distributor though. The bowl vent would go the filter housing, I would imagine. Not all carbs have that so its not important. The other hose, no idea.
Got anothe view? Lik from th overhead showing the whole bay? That sure looks like a stock carb from another manufacturer vehicle.
superj is offline
post #5 of 8 Old 06-18-2013, 02:42 PM
superj
You sure that's not a stock carb made by weber? Like a stock replacement for the carter?
superj is offline
post #6 of 8 Old 06-19-2013, 10:48 AM Thread Starter
Wranglin88yJ42
Sorry for the delay, I work nights once in a while. Here is a photo of the engine bay:
http://s1329.photobucket.com/user/Wr...247e8.jpg.html
You can see where the carb used to sit at 1 o'clock from the fuel fiter.
I also included one shot of the carb where you can see the back, which wasn't visible before:
http://s1329.photobucket.com/user/Wr...tml?sort=3&o=1
Last I included a few pictures of the carb fully removed, in case that helps:
http://s1329.photobucket.com/user/Wr...b8dce.jpg.html
http://s1329.photobucket.com/user/Wr...405c9.jpg.html
http://s1329.photobucket.com/user/Wr...cb96b.jpg.html
You were correct, this is not the original Carter. I assumed it was since the rig only has 90K orig. on it, but once removed I can see that it says "UREMCO Remanufactured" on one side and "Carter-Weber 273" on the other. If you have any advice or knowledge as to what connections are important/relevant to the Weber K551-38 and which connections get plugged up/unused by the new Weber, that would be greatly appreciated.
First time doing a carb swap, want to make sure I'm doing it correct. Many thanks.
post #7 of 8 Old 06-19-2013, 12:02 PM
superj
do you have emissions or visual inspections of the engine in your area? that will decide what you need and what you don;t need?
a different weber, like a 32/36, a 34, or a 38 won;t have the bowl vent. my 32/36 and my 34 didn;t have it. all the 38s didn;t have them in the pictures.
superj is offline
post #8 of 8 Old 10-02-2013, 02:14 AM
fabin4130
Start by throwing everything that is conected to the original carb in the garbage. get down to a bare intake plug all necessary vacuum ports find a key on hot wire a you vacuum advance hose and a plug to fit over the float bowl vent hose thing you don't need it.
fabin4130 is offline
