flipped Dana 300 and crawl box - Page 3 - JeepForum.com
 1Likes
post #31 of 57 Old 03-25-2013, 08:58 AM
Flajeeper1
1987 YJ Wrangler
Thanks for the pics. Nice work!
Flajeeper1 is offline
post #32 of 57 Old 03-29-2013, 10:28 PM Thread Starter
lclark2074
Ok there's Ben a little progress l have cut the last 2 pieces
Then I put the cover on for mockup
Hopefully next week l will get down to my welder and start assembling the top.
My plan is to weld the corners in red.
Then weld the shift rails in blue.
Then I will take off the cover and weld the inside corners.
Then I will weld the inside shift rails in green.
Before I can do this I nead to get some fibreglass welding tape so there will be no spater on the shift rails.
night crew 226
lclark2074 is offline
post #33 of 57 Old 04-04-2013, 12:42 PM Thread Starter
lclark2074
Ok I got and weld most of the shift box .
Then I ground the inside .
Were the big ground spot is low range gear is. Next step is too mark out for indents. Then over drill the top of the shift rails and plug weld. Reground. And redrill for the indent springs. After this I will finish welding the shif rail box.
night crew 226
post #34 of 57 Old 04-11-2013, 11:23 PM Thread Starter
lclark2074
Ok I started to work on shift interlocks in the first pic is the three pices and a templet
In the next two pic is showing the templet being used to locate centers of the interlocks on the shaft
The next pic shows the pices assembled
After testing noticed that the one shift fork needed a spacer
[IMG]http://i544.photobucket.com/albums/hh341/lclark2
074/_DSC0075.jpg[/IMG]
night crew 226
post #35 of 57 Old 04-12-2013, 05:33 AM
Louie4
Looking good. I'm curious to see how the final welding goes on the shift rail.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #36 of 57 Old 04-12-2013, 12:33 PM Thread Starter
lclark2074
Hopfuly next week I will get a chanse to finish welding the shift rail frame.
In the next pic I have driled plug welded and redrilled for indents.
Next step is to setup testing the springs on the indents. To figure how thick plate will be.
night crew 226
post #37 of 57 Old 04-19-2013, 10:51 PM Thread Starter
lclark2074
Ok can anyone tell me what this is for
night crew 226
post #38 of 57 Old 04-20-2013, 05:51 AM
Louie4
Adjustment?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #39 of 57 Old 04-20-2013, 09:14 AM Thread Starter
lclark2074
Thy are for the indent springs.here's a pic
The welding looks bad but it works.
I also finished welding the shift rail box
night crew 226
post #40 of 57 Old 04-20-2013, 09:17 AM Thread Starter
lclark2074
night crew 226
post #41 of 57 Old 04-29-2013, 12:41 PM Thread Starter
lclark2074
Update plug welded the top of the spring indents and welded one of the shift rail guide end. Drilled and taped the rear shift fork. Then with the allen set screw marked the new shift rail holddown spots. Then driled and burred the spots. After this ground the interlocks for hits.
night crew 226
post #42 of 57 Old 01-09-2014, 12:16 PM Thread Starter
lclark2074
Ok its Ben a long time but lately I've ben working on the 231parts. And I got pics to start with http://i544.photobucket.com/albums/h...010_130535.jpg
night crew 226
post #43 of 57 Old 02-19-2014, 09:38 PM
ltrail
1984 XJ Cherokee
any updates on this setup? Been looking into this. I think some things are made difficult by over thinking the situation . Your setup seems real simple and effective.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #44 of 57 Old 02-20-2014, 07:29 AM
Norcal_chris
Norcal_chris's Avatar
Seems like a lot of work. When i was driver drop I just flipped my case and doubled the o rings on the stock setup, plugged the vent off the tailhousing and drilled a new one and ran it. It didnt leak at all.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #45 of 57 Old 10-13-2016, 11:31 PM Thread Starter
lclark2074
its finely in yes
night crew 226
