flipped Dana 300 and crawl box - Page 2 - JeepForum.com
post #16 of 55 Old 02-08-2013, 12:50 AM Thread Starter
lclark2074
Ok i got a New seal ordered toady. I put the input seal and front output seal in. No pics yet.
night crew 226
lclark2074 is offline
post #17 of 55 Old 02-13-2013, 12:06 AM Thread Starter
lclark2074
Ok I got the last output seal today and installed it today. Picked up some rtv gasket maker but I haven't picked up a 23/32 drill bit yet. For the 1/2 in npt tap.
night crew 226
post #18 of 55 Old 03-04-2013, 01:40 PM Thread Starter
lclark2074
Ok its Ben awhile I have drilled and taped the old shift rails and put the 1/2" npt plugs in.
night crew 226
post #19 of 55 Old 03-05-2013, 12:42 AM Thread Starter
lclark2074
next i put in the intermedit shaft and gear
I got 1 1/2 *1 rectangle tubing and 1 1/4 round stock for the shift rails. take picks soon
night crew 226
post #20 of 55 Old 03-05-2013, 01:55 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Get 'er done.
Joe Dillard is offline
post #21 of 55 Old 03-05-2013, 02:07 PM
TSEJEEPERS
Great post.
I have been thinking about doing this for quite some time.
Keep posting some of us are watching!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #22 of 55 Old 03-16-2013, 02:55 PM Thread Starter
lclark2074
Ok I got to work on dana. Made a jig for locating the shift rod guides. It made of 5/8 Dowell and a pencil.
The rectangle tubing is 1" x 1 1/2" with a .120 wall and is 11" long. Next pick is
The next pic is the beging of the shift rails tubes. The long ones will have seals put in them.
night crew 226
post #23 of 55 Old 03-16-2013, 08:30 PM Thread Starter
lclark2074
Originally Posted by TSEJEEPERS View Post
Great post.
TSEJEEPERS Tanks for your sorport Iam tring to do most of the work myself so it will take a little longer than I want but it will get done.
night crew 226
post #24 of 55 Old 03-21-2013, 01:31 PM Thread Starter
lclark2074
Progress update drilled the shift rail guides to 5/8"
Then I driled the 3 1/2" shift rail guids to 13/16" x 5/8" deep.for the shift rail seals and taped them to 7/8" 14
night crew 226
post #25 of 55 Old 03-21-2013, 01:40 PM Thread Starter
lclark2074
Next step was to drill 1" x 1 1/2" for the shift guides with 1 1/4" hole saw
and hears a pic afterwards
night crew 226
post #26 of 55 Old 03-21-2013, 07:35 PM
Louie4
"You pass butter"
Louie4's Avatar
Impressive. I can't wait to see more.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #27 of 55 Old 03-21-2013, 09:33 PM
Flajeeper1
1987 YJ Wrangler
How do you seal the shifting rods?
Flajeeper1 is offline
post #28 of 55 Old 03-22-2013, 12:56 AM Thread Starter
lclark2074
Ok the seal for the shift rods are an O ring seal. In this pic u can see a 1 brass nipple, 2 an O ring, 3 a shift rail tube.
How this works is that u tighten the nipple wich compress the O ring witch makes the seal. You can see ledge for the O ring in this pic
night crew 226
post #29 of 55 Old 03-23-2013, 07:20 AM
Louie4
"You pass butter"
Louie4's Avatar
I like it. I would venture to guess you wouldn't want to tighten it too much so you wouldn't squish the o-ring. Would you need some kind of loctite so the brass fitting doesn't work itself out? Or did you countersink it just enough so it would seal but not bottom out?
Lou
YJOTM July 2012
YJOTM February 2014
post #30 of 55 Old 03-23-2013, 09:47 AM Thread Starter
lclark2074
Yes your right but before I loctite it I will have to test it for leeks and how much drag.
night crew 226
