-   -   flipped Dana 300 and crawl box (http://www.jeepforum.com/forum/f12/flipped-dana-300-crawl-box-1471348/)
lclark2074 01-30-2013 11:18 AM
Iam starting to buld a flipped np231 into a flipped Dana300. I got some pics and will be posting them soon.
The goal is to keep the cost down by doing a lot of the work myself
Hopefully I can get the setup unto the jeep by the end of march
lclark2074 01-30-2013 12:01 PM
Ok here a http://i544.photobucket.com/albums/h...4/_DSC0003.jpg
johnboy68 01-30-2013 12:25 PM
Clickee free:
lclark2074 01-30-2013 10:53 PM
Here's a pic of new top offhttp://i544.photobucket.com/albums/h...4/_DSC0004.jpg
lclark2074 01-30-2013 11:01 PM
Next I pulled the intermediate shaft and gear http://i544.photobucket.com/albums/h...4/_DSC0006.jpg
lclark2074 01-31-2013 11:29 AM
Next came the shift forks and shift rods
http://i544.photobucket.com/albums/h..._DSC0007-1.jpg http://i544.photobucket.com/albums/h...4/_DSC0008.jpg
As you can see in the first photo ther is two Allen set screws that got to come out.
lclark2074 01-31-2013 12:30 PM
Next comes the shift rods. I put the F and B in neutral then rotated the B 90*and pulled the rod out then pulled the front rod http://i544.photobucket.com/albums/h...4/_DSC0009.jpg http://i544.photobucket.com/albums/h...4/_DSC0009.jpg
timatoe 01-31-2013 02:23 PM
You do all your work in the back of the Jeep? PITA
lclark2074 01-31-2013 10:54 PM
Not at all but sometimes it works out that way it a good working hight.
lclark2074 01-31-2013 11:11 PM
The shiftforks
http://i544.photobucket.com/albums/h...4/_DSC0014.jpg
And the front bearing cover
http://i544.photobucket.com/albums/h...4/_DSC0013.jpg
Next l cleaned, cut and drilled the front cover
http://i544.photobucket.com/albums/h...4/_DSC0017.jpg
http://i544.photobucket.com/albums/h...4/_DSC0018.jpg
lclark2074 02-01-2013 09:02 AM
Next addressing the tale housing. It needs a 1/4" npt plug ware the old vent is
http://i544.photobucket.com/albums/h..._DSC0003-1.jpg
Housing off
http://i544.photobucket.com/albums/h...4/_DSC0015.jpg
http://i544.photobucket.com/albums/h...4/_DSC0019.jpg
For the plug I used a 7/16" drill and a 1/4" npt tap.
http://i544.photobucket.com/albums/h...4/_DSC0020.jpg
I also removed the old oil seal.
lclark2074 02-04-2013 11:03 PM
Next step is to check the input gear, Bering and seal removal
http://i544.photobucket.com/albums/h...4/_DSC0022.jpg
http://i544.photobucket.com/albums/h...4/_DSC0021.jpg
Sort I have no pics of this but I took off the snapring. Then slid off bearing out of the case. Then with a press pushed the bearing off the input shaft. Then I cleaned the case removed the seal. Next step was to reinstall the parts without the seal.
http://i544.photobucket.com/albums/h...4/_DSC0023.jpg
http://i544.photobucket.com/albums/h...4/_DSC0024.jpg
lclark2074 02-05-2013 10:57 PM
My new seals came in today. But instead of getting 1input and 2 outputs. I got 2 inputs and 1 output. I will have to contact morris 4/4 and get a new output sent to me. I will put the good seals in. Then I will try to get a 1/2 npt tap and drill bit for the old shift rails.
Joe Dillard 02-05-2013 11:52 PM
Looks like its coming along well.
I have lots of friends who run the D300 with a crawl box (4:1) in there YJ's. I've driven a few of them. Some were flipped while others were not due to front passenger side drop axle swaps. I liked the reduction they provide.
lclark2074 02-07-2013 08:48 AM
Joe thanks for your support . Right now I am not planning on the 4/1 but maybe later. Just stock gears in the Dana and np231.
The time now is 06:00 PM.
