flexing all day long! ( not suspension either) - Page 2 - JeepForum.com
post #16 of 33 Old 03-13-2013, 02:42 PM Thread Starter
stuckparatroope
Well....the plot thickens...the trans shop just called and said that it does not need a rebuild and that its in good shape! I'm at a total loss now...anyone know if that plate/ spacer could even cause this?
"If a trail breaks your jeep....this is a formal insult, grounds for retaliation from the jeep gods in the form of a motor swap, bigger lift kit, bigger tires, and a grudge run at it....break out your cameras boys...and, WATCH THIS!!!!" - last words before the demise of my favorite jeep!
stuckparatroope is offline
post #17 of 33 Old 03-13-2013, 03:07 PM
OKwranglerYJ
I'm pretty sure they will because people swap 4.0 heads for fuel injection in the 4.2 and have to put the 4.0 flywheel on for the CPS.
OKwranglerYJ is offline
post #18 of 33 Old 03-13-2013, 04:38 PM Thread Starter
stuckparatroope
Anyone know if the 999 and 727 flex plates and torque converters are interchangeable... beginning to think I may have got the wrong torque converter...
post #19 of 33 Old 03-13-2013, 06:20 PM Thread Starter
stuckparatroope
post #20 of 33 Old 03-14-2013, 04:19 PM Thread Starter
stuckparatroope
So...today I got my trans back from the shop...no issues there, but I get thinking... this jeep has what looks to be a worn out 2-2.5" lift, and the PO has done a 1-1.5" TC drop...any chance that the TC drop is putting too much strain on the transmission if the springs are worn out, and causing the rear of the trans to drop...putting pressure on the bottom of the torque converter/flex plate??? I know its a long shot, but I'm running out of ideas as to what the culprit is!!
post #21 of 33 Old 03-14-2013, 04:24 PM
OKwranglerYJ
Your reaching too far with that one.
post #22 of 33 Old 03-14-2013, 05:10 PM Thread Starter
stuckparatroope
Crap. Really thought I was onto something there..
post #23 of 33 Old 03-15-2013, 02:15 PM Thread Starter
stuckparatroope
Anything I may be missing before I put this thing back together? I can't think of anything that I haven't checked/ replaced.
post #24 of 33 Old 03-15-2013, 02:19 PM
OKwranglerYJ
Did you get the spacer ring?
post #25 of 33 Old 03-15-2013, 02:27 PM Thread Starter
stuckparatroope
No, never found out if I needed it or not, but I'm gonna put it back together without it unless I find out otherwise before tomorrow.
post #26 of 33 Old 03-15-2013, 02:45 PM
SeanB95YJ
sounds like the transmission shop you (almost) used was a decent one... they could've just gone ahead with the rebuild for the $$ but instead called and told you it didn't need it
I'd stop by your nearest Dunkin Donuts and pick up an assorted dozen, and a box-o-joe and stop by the tranny shop.. while you're dropping off your thank-you coffee break, see if you can pick their brains about the need (and location) of the spacer
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #27 of 33 Old 03-15-2013, 03:13 PM Thread Starter
stuckparatroope
Yeah I'm definitely impressed, not too many honest shops out there anymore, Especially trans...they will get my business and recommendations from now on he's putting new bushings in since its apart, hour of labor and $30 parts, he said if I didn't want the bushings put in, $50 out the door for checking it out, and new filter, and vent relocation, $100 out the door with bushings! I talked to the stealership today and they said it shouldn't matter about the spacer, and talked to the lead mechanic for about 20 minutes, he's stumped too, said to just put it back together and if I needed any part numbers or torque specs to let him know....something strange going on in this town with all the help from people lol. That "spacer" is just designed to spread out the torque, correct? No other reasons for it?
post #28 of 33 Old 03-16-2013, 03:04 PM Thread Starter
stuckparatroope
post #29 of 33 Old 03-16-2013, 03:14 PM
OKwranglerYJ
Pm mean max he is the best in the business for transmission work.
post #30 of 33 Old 03-16-2013, 03:56 PM Thread Starter
stuckparatroope
Good deal thanks!!
4.2 , flexplate , transmission help , transmission issue
