"flat" towing question. - Page 2 - JeepForum.com
post #16 of 26 Old 01-23-2014, 09:21 AM
StanF
If you're going to be towing a lot, and don't want to mess with the driveshafts...two options
1) Just swap over a TJ transfer case
2) Install the Tera 2 Low into your existing transfer case.
http://www.teraflex.biz/2wd-low-range-kit.html
StanF is online now
post #17 of 26 Old 01-23-2014, 09:57 AM
jbolty
jbolty's Avatar
Or, swap in a different shift selector plate with a neutral setting.
All the info is linked in the thread I posted earlier.
As for the stock slip yoke, if you have that you need to be carrying one of these.
http://www.harborfreight.com/transmi...ool-98060.html
jbolty is offline
post #18 of 26 Old 01-23-2014, 11:30 AM
StanF
snip
Roger that...but since that time, there's been a bunch of discussion about driveshaft removal. Trying to reiterate the other options.
Installing a TJ shift selector plate would be the least expensive option, I would guess...
StanF is online now
post #19 of 26 Old 01-23-2014, 01:17 PM
jbolty
jbolty's Avatar
Before I put in the true neutral plate I popped off the drive shaft from each pumpkin and strapped them up to tow. Only takes a couple minutes. But, after a trip to Big Bear and doing it in the snow I had my fill of that.
Just to clarify towing is only an problem in two cases. If you have a lunchbox locker in the front or are trying to use a two tire dolly. Otherwise there is no issue.
jbolty is offline
post #20 of 26 Old 01-23-2014, 04:24 PM
bpounds
bpounds's Avatar
Thanks for clarifying that. Because I've been towing this thing all over hells half acre, 4 down like the manual says, and no issues that I've noticed. Planning to flat tow about 2k miles this fall.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #21 of 26 Old 01-23-2014, 09:04 PM
az_zoner
I'm another YJ flat tower. We have thousands of miles now flat towing our YJ behind our motorhome. We put it 1st or 3rd gear and the transfer case in neutral. We double check by letting the clutch out while the engine is running to make sure we are in neutral. Never have had an issue.
Oh, and the key in the unlocked steering position.
CB
az_zoner is offline
post #22 of 26 Old 02-05-2014, 05:31 PM
smooved
any recommendations on a tow bar? a buddy recommended the stowmaster 5k, but they seem rich when accounting for a mounting plate.
thoughts?
smooved is offline
post #23 of 26 Old 02-05-2014, 05:41 PM
bpounds
bpounds's Avatar
thoughts?
I just use the $99 (less with coupon) tow bar from Harbor Freight. It is strong, easy to mount to a stock bumper, and does everything I need. It does not collapse or self-adjust, so hitching up takes perfect alignment with the ball, just like any other trailer. Doing it by yourself can take a few attempts. It doesn't come with safety chains, so that is an added expense.
If you want to spend the money for one that self-adjusts, or if you want to integrate Jeep brakes into the rig, then there are other options, like Blue Ox. $$$
Bill
bpounds is offline
post #24 of 26 Old 02-05-2014, 07:29 PM
YJames90
YJames90's Avatar
We double check by letting the clutch out while the engine is running to make sure we are in neutral. Same here but automatic
My 2.5 to 4.3 swap thread
YJames90 is offline
post #25 of 26 Old 02-05-2014, 07:36 PM
YJames90
YJames90's Avatar
its all here
http://www.jeepforum.com/forum/f12/t...65/index6.html
YJames90 is offline
post #26 of 26 Old 02-05-2014, 09:52 PM
smooved
Originally Posted by bpounds
I just use the $99 (less with coupon) tow bar from Harbor Freight. It is strong, easy to mount to a stock bumper, and does everything I need. It does not collapse or self-adjust, so hitching up takes perfect alignment with the ball, just like any other trailer. Doing it by yourself can take a few attempts. It doesn't come with safety chains, so that is an added expense. If you want to spend the money for one that self-adjusts, or if you want to integrate Jeep brakes into the rig, then there are other options, like Blue Ox. $$$
thanks bpounds! much appreciated. I'll pull those into my research pile.
smooved is offline
