Flat tow in 5th or N? - JeepForum.com
post #1 of 33 Old 08-09-2011, 01:10 PM Thread Starter
TheNewbie
I'm building my tow bar tomorrow and going to Ouray on Friday. I've read a lot of onfo on flat towing YJ's, but there seems to be some conflicting info when it comes to the tranny.
Should I be in 5th or neutral? and why?
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 33 Old 08-09-2011, 01:31 PM
Xpress
Why would you be in gear when flat towing? Common sense would tell you to put the vehicle in neutral, and not engage ANY parts of your drivetrain...
All about that unibody life.
Xpress is offline
post #3 of 33 Old 08-09-2011, 01:33 PM Thread Starter
TheNewbie
And that would be my first assumption as well. And I've read posts by a lto of people who tow in N and have no problems. But 1/2 of the people out there put it in 5th. I seem to remember reading about some reasoning for having it in 5th over N. Like maybe something about keeping the fluid moving in the t-case to keep from burnign it up or somethign like that. But I can't remember now.
post #4 of 33 Old 08-09-2011, 01:49 PM
dancytron
It has to do with something not getting lubricated that moves when the both transfer case and transmission are in neutral. You also need to make sure the CAD doesn't lock the front axle.
The owner's manual says:
1. Put in 2wd high
2. Drive 10 ft to make sure front axle not locked and 4wd light is off
3. Shift transmission into neutral
4. Turn engine off with key in unlocked position
5. Shift transfer case into neutral
6. shift transmission into gear
dancytron is offline
post #5 of 33 Old 08-09-2011, 01:54 PM
LilyBayXJ
You want the transmission in 5th gear. It neutral, even though the vehicle is not it gear, the transmission still slowly turns due to the motion of the vehicle. This causes added wear on the transmission components. So put it in 5th.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #6 of 33 Old 08-09-2011, 01:54 PM Thread Starter
TheNewbie
OK, so 5th is actually to STOP the movment in the tranny?
1. Put in 2wd high
Easy enough. Thanks
I guess 5th gear it is...
post #7 of 33 Old 08-09-2011, 01:55 PM
Andywear
What?!?!?
Wait, I get it.
But someone please explain to the others who dont understand.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #8 of 33 Old 08-09-2011, 02:04 PM
SquidsYJ
Don't forget to check the E-brake and make sure it isn't engaged. It's one that is commonly missed and can be bad for rear brakes and axle seals.
When I bought my CJ5 and flat towed it home, I unlocked the front wheels and pulled the rear drive shaft. But that is mainly because the PO said that the TC had a broken tooth. That ended up not being the case, but I didn't know that at the time.
SquidsYJ is offline
post #9 of 33 Old 08-09-2011, 02:09 PM
jbolty
jbolty's Avatar
If you have an aussie locker, or similar in the front you *may* need to pull a drive shaft.
Check here, the answer to the problem is starts in post #12.
http://www.jeepforum.com/forum/f12/y...roblem-595457/
Until I got this fixed I pulled both drive shafts off at the pumpkin and strapped them up.
jbolty is offline
post #10 of 33 Old 08-09-2011, 02:22 PM Thread Starter
TheNewbie
Nope, just an open diff up front.
post #11 of 33 Old 08-09-2011, 05:55 PM
Xpress
1. Put in 2wd high
This makes more sense to me. Keeping the tranny and t-case fluids moving makes perfect sense when moving on the highway at speed.
Xpress is offline
post #12 of 33 Old 08-09-2011, 06:33 PM
AaronJ
If you tow a manual transmission equipped Jeep with the rear drive shaft connected and the wheels on the ground you are going to spin the main shaft of the transmission no matter what. If you put it in 5th, not only will the transmission still turn but the engine will also be turning. I'm not sure about your logic there. You can't prevent at least part of the transmission from spinning unless you remove the rear drive shaft or stick the thing on a flatbed.
If someone does tow in this manner and backs up (reverses) the tow vehicle, you will be spinning the Jeep's engine backwards. Not a huge issue for some engines but very bad juju for others.
AaronJ is offline
post #13 of 33 Old 08-09-2011, 07:08 PM
dancytron
No the engine doesn't spin because the transfer case is in neutral. That's why you can flat tow without unhooking the driveshaft, where a regular vehicle without a transfer case you have to unhook the driveshaft to flat tow it.
post #14 of 33 Old 08-09-2011, 07:16 PM
AaronJ
Meh, you have a point, I was assuming the transfer case was still in gear since there was concern about the transmission turning.
In that case I think I can see where the "put in in 5th gear" comes from.
AaronJ is offline
post #15 of 33 Old 08-09-2011, 07:38 PM
timatoe
timatoe's Avatar
The important thing to know here is the tranny goes into 5th and the t/c in Neutral, leave the e-brake off, and the key on so the steering will turn.
timatoe is offline
Just got a flat....! HELP! SpikeSW JK Wrangler Technical Forum 2 02-04-2011 06:59 AM
Making a flat belly very flat Recoil TJ Wrangler Technical Forum 6 09-19-2009 10:24 PM
flat tow Poke YJ Wrangler Technical Forum 12 02-03-2009 06:13 PM
Flat Tow IJP2 YJ Wrangler Technical Forum 4 03-16-2007 01:55 PM
What Do I Need to Flat Tow My TJ? Which tow bar? JeepinYahoo TJ Wrangler Technical Forum 5 03-10-2007 08:33 PM
