Flat leaf springs? - JeepForum.com
post #1 of 7 Old 09-21-2008, 10:08 AM Thread Starter
Craig1319
Flat leaf springs?
I just bought a 1989 Jeep wrangler.
Now the leaf springs are completely flat. Im sure this isnt normal.
Whats a cheap easy fix or replacement?
also one more quick question that i didnt see enough point in making another new topic..
I need a torx set for my dashboard and such. Whats something cheap I can pick up for those bolts?
Craig1319 is offline
post #2 of 7 Old 09-21-2008, 10:15 AM
OneCleanYj
No, it's normal, that just happens to stock springs, esp. if you have a hard top. Even some aftermarket springs sadly sag after time. You can install an add-a-leaf, or get some stock replacement springs.
As for the bolts, I guess a cheap set of bits from the hardware store?
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #3 of 7 Old 09-21-2008, 10:35 AM Thread Starter
Craig1319
okay great, good to know.
What if i were to eventually put on a lift kit of some sort. Would i need to replace the leaf springs?
post #4 of 7 Old 09-21-2008, 10:39 AM
88TNSahara
Yes, suspension lifts will replace the leaf springs. Depending on how high you want to lift, a suspension lift will be anywhere from $450 and up. You can buy stock replacement springs from Quadratec or the like for ~$75 each.
88TNSahara is offline
post #5 of 7 Old 09-21-2008, 10:40 AM
OneCleanYj
It all depends on how much lift you want, what you're going to be doing with the Jeep, and what you're willing to spend. An A-A-L might give you enough to clear 31's, although they might rub when flexed. There's the option of installing longer shackles, adding a body lift, both of which can give you anywhere from .5" of lift to say 4" of lift if both are used, which requires a 3" BL and 2" shackle lift. 3" BL is UGLY and 2" shackles are waaaay too long, as most would agree in here, and they net you only a true inch of lift anyhow.
So no, you don't have to change the leaf springs, but you can.
post #6 of 7 Old 09-21-2008, 12:22 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
Welcome to the jeep world.
Are you a first time jeep owner?
Flat springs are normal after some years.
It's the reverse arched or "twisted" spring you have to look out for.
When I got my rig it had stock shackles and bushings still. A greasable set of shackles (like the MORE's) will net you loads of ride comfort and some flex.
As for the Torx bolts...get rid of each and every one of them with the appropriate size hex, cap, pan, or whatever head replacement...you may have to get familiar with your drill bits to remove the Torx stuff.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #7 of 7 Old 09-21-2008, 02:28 PM Thread Starter
Craig1319
yaa im a brand new jeep owner. I'm 18 and this is my first vehicle =]
Flat Leaf Springs jaycal3 YJ Wrangler Technical Forum 6 07-28-2009 02:48 PM
89 YJ - rear leaf springs flat, need replacement help divenutt YJ Wrangler Technical Forum 1 05-02-2009 05:05 PM
removing 1 leaf from leaf springs skipilot YJ Wrangler Technical Forum 2 02-25-2009 02:37 AM
Front leaf springs same as Rear leaf springs? JayJEEPguy YJ Wrangler Technical Forum 5 12-02-2003 11:53 PM
Leaf springs are pretty flat YJ4play YJ Wrangler Technical Forum 3 10-28-2003 09:43 AM
