FLASHER - JeepForum.com
post #1 of 5 Old 10-05-2001, 11:30 PM Thread Starter
gatt
FLASHER
NEITHER ONE OF MY DIRECTIONAL SIGNALS BLINK. I THINK IT IS THE FLASHER LOCATED IN THE FUSEBOX. HOW THE HECK DO I GET IT OUT? I'VE PULLED IT, PUSHED IT, TURNED IT, AND I CAN'T GET IT OUT. ANY IDEAS?
gatt is offline
post #2 of 5 Old 10-06-2001, 12:31 AM
Nightclaw
Did you push and turn at the same time? I've never replaced one in a Jeep, but some are "twist-lock" style.
Nightclaw is offline
post #3 of 5 Old 10-06-2001, 08:30 AM Thread Starter
gatt
yes, i did push and turn but it still didn't release! thanks for the reply! anyone else have any ideas??
gatt is offline
post #4 of 5 Old 10-07-2001, 07:03 AM
Jeep Chic
First, what year Jeep is it? I replaced my fuse for the blinkers with a bigger one. What I mean by bigger is, instead of a 20 I went with a 30, due to all the electrical I am running...winch..radio..CB and other stuff.
I also replaced the stock steering column to a tilt column. I had to use the old turn lever on the "new" column, and to get it out, you have to twist and pull. If you simply pull, you will break the lever.
Jeep Chic is offline
post #5 of 5 Old 10-07-2001, 03:38 PM Thread Starter
gatt
it is a 94 wrangler. its the flasher i want to replace, not the fuse. the flasher (well i think it is the flasher) that makes the directional signals blink is located at the top of the fuse box and is about an inch in diameter. just can't get the damn thing out!
gatt is offline
LED Flasher help WMiller13 YJ Wrangler Technical Forum 5 08-08-2007 06:25 AM
LED Flasher? Help! stathunter TJ Wrangler Technical Forum 4 05-02-2007 12:26 PM
why do we need a $32 flasher?????? cincytj TJ Wrangler Technical Forum 18 10-12-2005 06:56 AM
Where is my flasher?? heckel TJ Wrangler Technical Forum 7 09-26-2002 12:15 PM
