Fixing Rotted Out Skid Plate Mounts - JeepForum.com
post #1 of 25 Old 05-03-2010, 07:27 PM Thread Starter
parkerm26
So after i blew a ujoint, and had my JB Conversions SYE ordered (the u joint didnt last long enough), i decided to remove the tcase cuz thats the way my friend wanted it to do the SYE. with a friend i could practiaclly rip all the skid plate bolts out of the frame. so it was time for remaking the bottom of the frame rail. This is the frame after removing the skid
Drivers Side:
Passenger Side:
Damage to Pinion (not a big deal) What are those little "bridges" called? and how much they are?
i welded in the new pieces today. They were 27 inches long. 2.5 inches wide. 1/8 in thick cold rolled steel. The holes are 5/8 inch diameter in the center of the strip. the holes are 9 3/16 and 8 3/16 apart on center. on one side i welded 1/2in (3/4in socket) Grade 8 nuts with the holes centered so bolts could easily fit through. both are identical. i drew a sketch cause i forgot to take pictures of the pieces but my mac wont let me upload it to image shack. PM me your email if you want the sketch. more pics to come tomorrow of the finished job. forgot to take pics today i was too tired and covered in burns from welding, grinding, cutting, etc. it sucked. The bolts im using to hold the skid plate up are 1/2in x 2in grade 8. i hope theyre long enough with an 1/8in washer. havent test fitted the skid because its here at my house and the jeep is down the street at a friends shop and needs towing. More pics tomorrow night!
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #2 of 25 Old 05-03-2010, 08:30 PM
Area.3.Fiftyone
If you welded the nuts to the plate, they are no longer grade 8. The heat from welding them reduces their hardness.
You can get a U Joint strap kit at just about any good auto parts store. It will come with new bolts and straps.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 25 Old 05-04-2010, 06:04 AM Thread Starter
parkerm26
Yeah thats what the engineer said who helped me. better starting with grade 8 that something else i would assume. idk if stainless would have been better. but the bolts are grade 8 and thats where i really need strength. thanks for the info on the straps
post #4 of 25 Old 05-04-2010, 11:48 AM
Area.3.Fiftyone
No problem.
Grade 8 bolts are only better for applications that require more shear strength any way. Those skid plate bolts are in tension, so it really doesn't matter.
post #5 of 25 Old 05-04-2010, 03:00 PM Thread Starter
parkerm26
cool thanks
post #6 of 25 Old 05-04-2010, 03:06 PM
littlejohn411
That frame looks just like mine.
I am using these for the repair http://www.quadratec.com/products/56011_9050_07.htm
If you can post some pics of what you did to fix yours.
Also here is the strap kit you need if you can't find it locally http://www.quadratec.com/products/52303_00.htm
GOT GUNS?
littlejohn411 is offline
post #7 of 25 Old 05-04-2010, 05:44 PM
notmyj
Originally Posted by IronMaiden View Post
No problem.
Untill your dragging it across a rock and it catches on a lip. Then its in a shear load. Lol
That being said, I used stainless button head bolts to hold my UCF skid on.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #8 of 25 Old 05-04-2010, 06:24 PM
NHfireLJ
NHfireLJ's Avatar
looking forward to intermediate and completed pics..
NHfireLJ is offline
post #9 of 25 Old 05-04-2010, 07:56 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
I did the exact same thing to fix mine. I have pictures but I'm too ashamed to post them because my welding looks horrible (but effective).
-John-
johnboy68 is offline
post #10 of 25 Old 05-05-2010, 08:15 AM Thread Starter
parkerm26
yeah my welding is horrible. i havent been down to see it yet since i did the job but i'll get the pics up asap
post #11 of 25 Old 05-07-2010, 12:35 PM
ExpeditionXJ
Originally Posted by littlejohn411 View Post
Just found this thread in a search..
I have a bud's 88 YJ in driveway, just finished the lift with the exception of the transfer lowering kit. On drivers side the formost bolt is gone.. and the rearmost just spins. I'm expecting it's rotted above the skidplate.
I just called Q'Tech about this part and they tell me it's a 4 sided piece.. meaning it cant simply be slid over the framerail and welded. Is this true?
I'm hoping that it's slightly wider than the frame and i can cut the top portion out and weld this in? Anyone have any experience with this piece?
ExpeditionXJ is offline
post #12 of 25 Old 05-07-2010, 01:49 PM Thread Starter
parkerm26
you do not want a "u" shaped replacement piece. this will just make your problem reoccur by trapping water. drilling drain holes is an option i guess. i did it this wat and only welded some parts. by doing this water can drain and excess water can evaporate.
and sorry these are cell phone picks thats why they suck
here is looking back from the front tire under the drivers side.
Same angle only the back portion of the new piece
and a look at my terrible welding and grinding. if you do this wear long sleeves, pants, and do it on a cool day so you can have something on your neck and face. hot metal burns suck
and done. with the frame anyway. still have to put the trans case back in with my new JB super short SYE installed, put the skid back up, and have the cherokee driveshaft cut and balanced. also doing front driveshaft u joints while im taking stuff apart. i'm thinking about cutting my cat out because i was told by the mechanic who did my SYE that i don't need it (cuz its a 93)and it might fall apart inside. any opinions? i'm not worried about the noise i'm an 18 year old kid hahaha just input from anyone that does not have a cat
post #13 of 25 Old 05-07-2010, 01:50 PM Thread Starter
parkerm26
why the pictures so small? i have no clue. they should be the same size as the first ones. ill try to fix that later. click on them for a better view sorry
post #14 of 25 Old 05-07-2010, 04:31 PM
littlejohn411
Quadratec is wrong,they are caps and slide right over the frame.
You need to notch the body mount to slide the cap all the way up then weld it all up.
GOT GUNS?
post #15 of 25 Old 05-07-2010, 05:48 PM
Petrucci
I just cut some angle iron to fit, drilled the skid plate bolt holes. Then tack welded the nut to the inside of the angle. I belive it was 3"-2" 1/4" angle and I welded it up solid to the frame. I Noticed a huge differance the jeeps alot more solid. But I also did the front steering box, and the rear shackle area frame repairs.....still a few more "weak" spots as well..lol
Petrucci is offline
JP0020 Skid Row engine skid plate mmarmouz TJ Wrangler Technical Forum 3 11-13-2009 10:06 AM
New skid plate/ TC Mounts InEmberClad YJ Wrangler Technical Forum 4 09-17-2009 10:29 PM
rear upper shock mounts !! rotted out.... bigbear91 YJ Wrangler Technical Forum 2 03-09-2009 03:15 PM
Fixing transfercase skid mount & repairing frame UltimatE YJ Wrangler Technical Forum 2 08-14-2008 12:15 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
