Fixing rear main seal leak? - JeepForum.com
post #1 of 10 Old 04-11-2007, 09:09 PM Thread Starter
wessy
Anyone have any advice on what parts I may need like a new gasket and ideas on how to do this? I will need it done in less than a week when I have a vehicle inspection.
Also does anyone know what box you have to remove to get rid of the "check emissions" light on the dash? This is on an 89 4.2 btw.
wessy is offline
post #2 of 10 Old 04-11-2007, 11:13 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
drop oil pan
pull out old two piece seal
install new two piece seal
reinstall oil pan with new gasket and rtv.
if you search you should be able to find at least a few write-ups from the last 6 months or so....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 10 Old 04-12-2007, 02:01 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
if you cant find the little silver box for the emmisions light, remove the 2 screws and take out the panel that covers the idiot lights, and remove the bulb....
rear main oil seal will be well covered in the haynes/clymer manual you (should) have already....
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 10 Old 04-12-2007, 02:21 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Look on the fire wall under the dash. To the right of the gas pedal about halfway up. It is a little plastic/silver box with one wire coming out of it. Threw mine out a while back so no pics. Its rather obvious. Its the only box near the right of the gas pedal. You can see if from the drivers seat.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 10 Old 04-12-2007, 03:14 AM
Axl Jack
rear main seal writeup:
http://jeepin.com/features/rearmain/index.asp
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #6 of 10 Old 04-12-2007, 05:09 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Before you go into this messy messy job, make sure it is the RMS that's leaking.
Many of us have fought with this only to find it was actually the valve cover gasket leaking (easy fix) and blowing back then dripping down the bellhousing making it look like RMS.
- Ernie
Richmond88yj is offline
post #7 of 10 Old 04-12-2007, 06:32 AM
saharajeepman
the little box for the emmissions light has a clear cover with little plastic gears in it right by the pedal as rescuer said. when u do the seal- just make sure that u get ALL of the old gasket material off. i had a problem in the back when i was putting mine back on-there was a little piece of the old gasket that i didnt see was still there. i also used a 1 piece gasket with the rtv to hold it in and seal it. good luck
'89 Sahara 4.2 258 Upstate, NY
31x10.5 BFG All Terrain, 470 cfm Holley Off-Road Avenger, Nutter Bypass,
RE 2.5, Currie Shackles front and boomerang rear
TJ front driveshaft, SYE, Tom Woods rear driveshaft, Posi-lok, AX-15 swap.
saharajeepman is offline
post #8 of 10 Old 04-12-2007, 06:33 AM
saharajeepman
post #9 of 10 Old 04-12-2007, 10:49 AM Thread Starter
wessy
cool thanks for all the help guys I will get that emissions box out and I have to fix the turn signal/wiper lever today. I also got a chiltons repair manual today and I will probably fix the rear main seal on monday during shop class although I may do it this weekend and then the jeep should be reaady for the insurance inspecion.
wessy is offline
post #10 of 10 Old 04-12-2007, 10:58 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i just did the RMS replacement to find out that it was just the rear oil pan gasket, the part where it mounts right up to the RMS. It was torn to crap, so before you go picking away at the RMS, b/c it does not slide right out, i even tried hitting it with a punch and a hammer, didn't budge, PB plaster got it out for me. I didn't attempt the top part of the RMS, since mine is a 2 piece, it would be impossible to get out w/o removing the trans. It says you just tap it with a drift pin and it slides out the other side and you just pull it out with some needle nose pliars...yea right....also, get some wire brushes for the drill but to scrape off all of the old oil pan gasket, chances are it will be stuck on there really really good if it is the stock gasket. And then get some razor blades to scrape it off the bottom of the engine.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
Rear Main Seal Leak? munroejp TJ Wrangler Technical Forum 10 11-29-2009 03:52 PM
rear main seal leak Vacant Stare TJ Wrangler Technical Forum 19 02-03-2007 01:43 PM
Leak - rear main seal... big job? BChamberlin TJ Wrangler Technical Forum 11 03-13-2006 08:00 PM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
Rear Main Seal Leak Optik45 TJ Wrangler Technical Forum 19 08-28-2004 11:38 PM
