Fix for a leaking diff fill plu? - JeepForum.com
post #1 of 2 Old 03-01-2002, 12:54 PM Thread Starter
jeepinarkansas
1982 CJ8
Changed my rear diff fluid and realized after the fact that the leak was coming from the black rubber fill/check plug. Any fix to this problem without buying a new cover? Would the same silicone adhesive work around the plug after it is filled?
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 2 Old 03-02-2002, 06:56 PM
jepthng1
the plug is just a couple bucks at the dealer. or if you had to clean it off with
brake clean and apply some rtv sealer.
be safe buy a new plug
jepthng1 is offline
4.2 leaking oil out of oil fill cap? Yarz YJ Wrangler Technical Forum 13 09-26-2009 09:22 AM
D35 Fill Plug leaking?!? JeSimmers TJ Wrangler Technical Forum 4 04-24-2008 08:15 PM
diff fluid - better to under fill then over fill? 4lo2.5 TJ Wrangler Technical Forum 2 04-20-2006 07:22 PM
Leaking fill plug on D35 4cylYJ YJ Wrangler Technical Forum 11 06-24-2005 04:35 PM
